Results 1 to 16 of 16
Thread: Repairing skimmer pipes
    Hello All
    I'm going to try and repair my collapsed skimmer lines, I'm breaking the concrete tomorrow
    I would just like some information before hand, at some point the flexible pipe turns into PVC. I know that attached to bottom of the skimmers is the flex pipe, but at the pump I have PVC coming out of the ground. I'm wondering if I just need to find were the flex ends and replace that portion with the polyethylene pool and spa tubing I can get at home depot (I'm hoping that is the correct type of pipe to use).
    I mean if I have to replace it all I will, but just replacing the flex pipe will make it so l don't have to break a lot of concrete.
    Also, if I do have to replace it all is the PVC portion just regular PVC or do pools use a different type of PVC?
    Thanks for any advise or suggestions ...
    Fatcat07, In ground pool, Vinyl Liner, 18 X 36 Pool size, 30,000 Gallons
    Hayward Heat Pump - Hayward HeatPro Heat Pump
    Hayward Filter DE2420 - 24 sq ft (I think)
    Hayward pump - Not sure of the model number
    Suffolk, long Island
    Repairing my skimmer lines
    Sorry, I originally posted this in wrong forum
    Hello All
    Thanks for any advise or suggestions ...:handwave
    Feb 2014
    Upstate, NY
    390
    Re: Repairing my skimmer lines
    Schedule 40 PVC. Are you certain what the problem is ?? I would think you need to visibly inspect all of the flex pipe if you think it is damaged. Wow, big job !!!
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Quote Originally Posted by Donny View Post
    I had two different pool companies come to work on filter/pump because I thought the issue was air getting in to the system, both companies came to the same conclusion and I was not happy
    Than they quoted me the price to fix it
    So now I will attempt to fix it myself, I'm hoping it is just the flex pipe which I can actually see collapsed and not the whole run. It actually makes sense why would I be able to pull from the main drain good but only get a trickle when I go full skimmers
    Feb 2014
    Upstate, NY
    390
    Oh boy, that is a shame! My IG pool has the flex pipe from the skimmers all the way back to just before the pump. Are you losing water when using the skimmers ??? Just curious.
    Well I will cut the concrete and dig out the line until I hit PVC, than hopefully the PVC is good and I will just replace the flex pipe. The funny thing is the pipe that connects both skimmer lines to the pump is under the concrete so at some point I am going to have to decide whether to follow the pipes or just cut straight back and make a new connect to the 3 way Valve
    No I don't seem to be losing any water, my water level hasn't changed and I have been running the intake at half and half.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Repairing skimmer pipes
    Couldn't think of anything better to do, huh? Pools use schedule 40 pvc, which is probably what you think is regular pvc. It is not polyethylene. Yes, you need to dig up the flex pipe and replace it with Sch40 pvc.
    Good luck!
    Quote Originally Posted by pooldv View Post
    Good luck!
    Thanks poolv .....
    Do you know if sch40 PVC is available at home depot or can you only get it at pool supply stores?
    Lol ... I was/am very excited about my new heat pump, but jezz things just started piling up.
    My mantra is warm/hot water by Memorial Day!!!! Whatever it takes
    My BBQ will be all the more enjoyable once I get everything up to par ..
    Nearly all Home Depots carry schedule 40 PVC in both 1.5" and 2". Don't go to pools stores if you can help it If you need some strange fitting Home Depot doesn't have it is best to try the Internet or a plumbing supply place.
    My guess is that it is flex from the pool until very close to the equipment pad, and only changes to rigid directly below where it comes out of the ground.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Schedule 40 PVC is available almost anywhere that sells PVC plumbing stuff.
    Thanks everyone
    Well it time for bed ....
    Wish me luck
    Warm/hot water by Memorial Day ...
    DFW, TX
    24,502
    Quote Originally Posted by fatcat07 View Post
    Right on!
    Feb 2014
    Upstate, NY
    390
    How about running a snake down the (2) skimmer lines and see how far you get ?? It may give you an idea just where the blockage is ??? Well if you are not losing water obviously no leak is present. Just a thought. Good Luck!
    Feb 2014
    Upstate, NY
    390
    Think we have two threads going. Other thread is in the Pumping Station.
    Lol
    Donny, that's my fault I here 1st than realized I should have posted in the pumping station forum
    Topic merged. JasonLion
    Feb 2014
    Upstate, NY
    390
    No biggie at all, I just want you to get all the help you need. This site has helped me a great deal. Another suggestion would be to hire a company with a Drain Snake Camera. Then for sure you would see what's going on in the skimmer lines. It would be great if you could rent such a snake, not sure that is an option though.
