Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: Just tested, looking for input, all help appreciated!
    Apr 2015
    Waxhaw, North Carolina
    21
    Hi, I'm new here, just tested with my K-2006c.
    FC= 14.0 ppm
    CC may be 0.5 to 1.0 but it may have been going back to red before adding, so it may be 0.0
    PH=7.0 (3 drops raised it to 7.4)
    Alkalinity was 40 ppm
    Calcium was 30 ppm
    CYA=60ppm
    All help is appreciated. The calculator said to add 60 oz of borax by weight.
    It also said to add 613 oz of calcium chloride, but I don't know if that is necessary.
    Please let me know what you think.
    muc
    Waxhaw, NC, 20K Gal, 16x36 IG vinyl pool, hayward 300 lb. sand filter, 1&1/2 hp one speed hayward super pump, solar and gas heaters, just finished building pool, K2006C test kit, Polaris 360 cleaner, will have SWCG (not wired yet). Building Concrete & tile hot tub with 3 HP pentair variable speed pump that will run into pool. Eventually will have waterfall running into hot tub into pool. Systems share water.
    38,262
    Re: Just tested, looking for input, all help appreciated!
    Welcome to TFP!!!
    You do not need to add calcium for a vinyl pool.
    You also can not test the pH accurately when the Fc > 10ppm, but you are certainly too low.
    How do you chlorinate? It is atypical for the TA and pH to be so low.
    And why is your FC so high?
    Apr 2015
    21
    Thanks for your reply! I am currently using bottles of bleach. It went green, so I added until it wasn't. I've put in about one box of borax and a couple pounds of baking soda last Friday. After a green weekend, I poured about 4 jugs of bleach, then Monday, I wa sick of green, added 3 more, and it turned blue. Still a bit cloudy, but not green!
    Oh, once it is hooked up, I will switch to SWG.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Well, if you are green you don't want to start the SWG, you need to SLAM using liquid chlorine only. Right now you are teasing the algae, a little chlorine here, a little there but not a sufficient quantity for a long enough time to keill everything in the water.
    No SWG, liquid chlorine.
    Read the SLAM article in the Pool School and follow the instructions fully to the end.
    Support the site
    Apr 2015
    21
    Thanks! It is not green now, is at FC 14, and was at 19 day before yesterday. If CYA=60, the chart says to take it to 24. I'm betting it was higher than that Monday, should I take it back that high? It has been clearing fairly well, just a little cloudy. Also, should I begin to add any borax? Thanks for your help, you rock!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,470
    Just because it isn't green does not mean there isn't still algae growing in your pool.
    Read this, SLAMing Your Pool
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Quote Originally Posted by pooldv View Post
    +1
    You need to SLAM. The M stands for Maintain! When a pool is green you need to get your FC level up to Shock level and *keep it there* until you pass all 3 tests to let it back down! (It's all in the SLAMming Your Pool article pooldv linked to.)
    It's a proven method to go from green to sparkling shiny clear!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Apr 2015
    21
    Thanks! Will do! Can my kids swim with it that high?
    Quote Originally Posted by Beens View Post
    +1
    Thanks. Will do! Can my kids swim with it that high?
    Casey's Avatar
    SW PA
    10,427
    Your kids theoretically could but if your pool water is cloudy, why would you want them to swim in a pool you couldn't see through?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Your water needs to be clear, and your CC needs to be 0.5 or less before anyone swims.
    Essential Links:
    Apr 2015
    21
    Quote Originally Posted by Casey View Post
    It's not that cloudy! I can see the details of my drains clearly. It just doesn't sparkle at this point.
    Thanks!
    Quote Originally Posted by Patrick_B View Post
    Okay. Thank you!
    DFW, TX
    24,470
    And your FC needs to be below shock level for your CYA, Chlorine CYA Chart to swim.
    Apr 2015
    21
    I tested this morning, FC = 12
    CYA was just over 50.
    I put in a 128 oz jug of 8.5 bleach, will test in a bit to see if another is needed. CC was below .5
    Chart says to shoot for FC of 20 ppm
    I haven't added any more borax or CYA.
    DFW, TX
    24,470
    Please update your signature as shown*here.
    Definitely don't add CYA during a SLAM.
    Apr 2015
    21
    Thanks! I won't!
    Apr 2015
    21
    Tested this afternoon.
    FC = 15.5
    CYA=65
    Added 2 jugs of 8.5% bleach 256oz.
    It is getting clearer. Thanks everyone for the help. It's much more fun learning this myself than depending on local stores. You guys are a great resource, and I appreciate your efforts, coaching, patience with a rookie. This is very cool, and thank you for allowing me to be here and learn from you.
    muc
    DFW, TX
    24,470
    We're glad you're here and glad to share. TFPC is very cool!
    Apr 2015
    21
    Thanks!
    Apr 2015
    21
    Here's the latest:
    fC=20 (that's what pool math says it should be!)
    CC=0 to 0.5max
    PH=7.2 (one drop takes it to 7.6
    TA=40
    CYA=50
    Any words of wisdom?
    Thanks!
  20. Back To Top    #20
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I would not test anything other than FC and CC with the FC level you have. The PH test is not reliable above FC of 10.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
