Thread: levelling above ground soft side pool
    Jun 2014
    phoenix
    7
    last summer we installed our above ground pool for the first time. it was level about 3/4 of the way around it, however one corner was about an inch higher than the rest of the pool. it survived ok until we took the pool down for the winter. is the pool designed to allow for this and what do you recommend, in inches or fractions there of to be the max allowable "out of level"?
    INTEX ABOVE GROUND 18x9 POOL 52" HEIGHT ~4500 GALLON
    SAND FILTER PUMP MOD. #SF90110T
    AVG SUMMER HIGH TEMP. 106F
    AVG SUMMER LOW TEMP. 85F
    Re: levelling above ground soft side pool
    If the highest and lowest points are within one inch of each other vertically you should be fine.
