Thread: End of Slam questions?
    Mar 2015
    Orlando FL
    28
    Hi Guy's 'n' Girls,
    Just coming to the end of a 5 day Slam, OCLT last night/this morning was FC 0.5-1ppm and CC 0.5ppm, but water still very slightly 'opaque' ( 7am). Not quite as 'Sparkling' as I would like, so decided to continue for another day. Now @ 2pm water looks really clear and sparkling (finally), but will continue and check again over night with a full set of tests (TF100) in the morning.
    Now the questions, I'm running out of time '"State side", three days left and still have my SWG to commision, Can I add my salt now whilst the FC is dropping? also how accurate will the CYA test be with the raised FC levels ( so I can adjust to the required for the SWG).
    Thanks.
    12x30 12K gallon plaster/gunite pool- 2x deck streamers & 2x fan sprays, 6x4 1k gallon 4 jet spa. 3Hp Pentair Intelliflo XF variable speed pump (pool/spa combi). Pentair clean & clear 100sqft cartridge filter, 400K Hayward NG Heater, Intermatic RC 2163FE Pool / Spa combi Analoguel Control. SGS 540 Breeze SWG. TF-100 with speedstir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: End of Slam questions?
    You can add salt whenever you think you're done backwashing the filter every few hours. While FC is dropping post-SLAM is an ideal time, because it needs to dissolve and mix for 24 hours before you turn on the SWG. The CYA test is unaffected by FC levels. Have you read about Diamond Day? Post 5
    30,419
    No reason not to add salt anytime now. CYA test is not related to FC levels whatsoever.
    Mar 2015
    Orlando FL
    28
    Thanks for the quick replies. Diamond day! now I just need to fly the Grand Children over to mix the salt LOL, or may be I'll just tell the wife there's diamonds in the pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    LOL, grandkids are great pool water mixers!
