Results 1 to 11 of 11
Thread: low/no solar heat questions
    Jul 2009
    Ottawa, Ontario
    16
    I have a few panels on the roof, and a solar controller. My current pool temp is 16C (60F) and according to the solar controller the temp at the collectors is 28-31C (85F ish). When the solar kicks in the water from the return is still cold, I notice very little difference between the solar being on or off. The temp on the roof panels also hardly changes weather the solar panels are running or not. It was working well when I drained it for the winter.
    I am looking for ideas on where to troubleshoot.
    Thanks in advance.
    24' Round Above Ground Round 46939 L
    1.5 hp Jacuzzi LRC Pump
    Laser 225 Sand Filter
    (5) 4x10 Ultra Swim collectors -roof mounted
    Hayward AQ-SOL-LV Solar controller
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: low/no solar heat questions
    Is there a valve to set the flow to and from the panels and is it set for 100% flow to the panels? What is the filter pressure and how are are the panels above the filter?
    Mark
    Apr 2015
    niagara falls, canada
    6
    I have 2 solar panels on two different sides of my roof. On one roof, the water needs to run uphill through the collectors. Does this mean that the tap at the end of this panel needs to be open in order to create a vacuum? Does this make sense?
    mas985's Avatar
    Pleasanton, CA
    11,737
    No to your questions but how about answering my questions?
    Mark
    Jul 2009
    Ottawa, Ontario
    16
    I just have the hayward 3 way valve that is controlled from the solar controller, and it is running to the panels. The pressure is about 14 according to the filter. The panels are on the 2nd story of my house, its about a 50' run of pipe to and from, the current outside temp is 20C, the panels are reading 34C. If that's not what you meant, let me know.
    The reply in the middle about 2 different sides of the roof was another person.
    mas985's Avatar
    Pleasanton, CA
    11,737
    14 PSI is a little low for a two story house. Is 14 PSI your normal pressure with solar?
    When solar is running, do you feel the water coming out of the returns?
    Does this mean they feel hot or cool?
    Mark
    Jul 2009
    Ottawa, Ontario
    16
    I just opened for the summer, from what I remember its about what it was last year. My pressure bypassing the solar is 13, with solar on is 14.
    The water feels slightly warmer than what is coming out of the return, definitely not a major noticeable difference.
    I have not been on the roof, I don't have a ladder, and will need to borrow one to check up there.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The water shouldn't feel that much warmer, only a little bit. That means the panels are performing efficiently. When the water feels hot, the water flow is too low. Same with the panels. the panels should feel cool and not hot to the touch.
    So did you mean the temperature sensor does not change? It shouldn't.
    Mark
    Jul 2009
    Ottawa, Ontario
    16
    yes, that's what I meant, the sensor says 31 even thought the cooler water is coming down. When i first turn it on the water is quite a bit warmer. I had remembered it being much warmer during the summer last year, but maybe that's just because of where the sun sits in the sky and the ambient temperature being warmer.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Sounds like it is working fine to me.
    Mark
    Jul 2009
    Ottawa, Ontario
    16
    Thanks for your help, i'll go with that. Thanks again for your time.
