Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: Relatively new pool owner starting the TFPC method
    Jul 2014
    Evansville, IN
    72
    First of all, I just had a new liner put in and refilled with municipal water. I think the company that put it in poured in stabilizer and shocked it. I brought the PH level up with baking soda and threw some chlorine tabs in the skimmer that were left over from last year. I ordered the T100 and will post my numbers in a few days.
    My first question- should I just throw away the old chlorine pucks since I read that they mess with the CYA? I only have about 10 pucks left, but I was planning on using them to save a couple of dollars.
    Throw away or keep? Thanks so much!
    16 x 32 Sport Pool; Hayward Series Sand Filter S244T
    15,000 Gallons, In Ground with New Vinyl Liner
    Pool approx. Five Years Old. Live in KY
    Re: Relatively new pool owner starting the TFPC method
    10 pucks shouldn't be a problem, especially on a pool that was just filled.
    Do you have anything to test with at all? It is good to monitor the PH when using tricolor tablets, as they are fairly acidic.
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    I know its not exactly the same, but i bought a bunch of powdered dichlor from Leslies before i got with this program. when i know my pool needs both chlorine AND CYA, i'll sprinkle that in instead of bleach to give me a couple more units. a lot of people still use pucks when they go on vacation - so they have a use, just be aware of your numbers.
    I've found the pool calc VERY useful to predict what will happen when you add "x" chemical.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Jul 2014
    Evansville, IN
    72
    Quote Originally Posted by JasonLion View Post
    Yes, I have one of those basic test that checks chlorine, ph, and alkalinity.
    Ordered T100 yesterday. Even bought the thing that stirs
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Quote Originally Posted by Darren35 View Post
    Excellent!
    Jul 2014
    Evansville, IN
    72
    Alright friends. Got my t100 and Mixer but am a little concerned with the numbers. I was very precise and careful. How does this look:
    FC: 1.0
    CC: 3.5
    TC: 4.5
    Calcium Hardness: 100 PPM (I have a brand new vinyl liner and filled pool two weeks ago) Been using pucks until now. Going forward I am doing your method.
    Alkalinity:150
    CYA: 35
    Also PH looked like 7.2. I used the blue box test for PH
    Thoughts?
    Jul 2014
    Evansville, IN
    72
    I just added 96 oz of 6% bleach per the calculator. This said it would raise my FC from 1 to 4. Not sure if I should slam it at this point. Thought I might just keep checking it a few times per day.
    Also, not sure if it matters, but I keep a solar cover on it and the pool water looks crystal clear
    Jul 2014
    Evansville, IN
    72
    2 hours later my FC is 17 and CC is zero lol
    38,532
    Clearly something is wonky ... either the first or second FAS-DPD test was not correct.
    With a CYA of 35ppm, you should never let the FC drop below 3ppm. So likely should target 5-6 every day. Still no idea how you got up to 17ppm though.
    DFW, TX
    24,514
    Good that your pool is clear. Ok, rule #1, never let you FC drop below the min based on your cya according to this Chlorine CYA Chart. Rule #2 keep your PH between 7.5 and 7.8.
    Everything else can be worked along the way.
    Here are the Recommended Levels for your pool.
    Use PoolMath to determine what to add to get to those levels.
    Have you read these?
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Recommended Pool Chemicals
    Jul 2014
    Evansville, IN
    72
    I just tested again. 17fC and 0 CC. Guess I screwed up the first test and should not have added the bleach. I said I was new lol. I am going to take the pucks out of the skimmer and check the FC and PH early in the morning. Thanks for the help. I will figure this out!
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    You can let the FC level drift down on its own, just be ready to maintain it again when it gets near your target FC level.
    If you need to bring your PH up, use either borax or washing soda (sodium carbonate), instead of baking soda (sodium BIcarbonate). Baking soda will raise your TA more that it will the PH.
    One more thing, avoid using the trichlor pucks in your skimmer, especially if your pump does not run 24/7. As noted above, they are acidic and can damage the skimmer and pump if used in the basket. Safer method here is if you ever use them, put them in a floater.
    Enjoy your pool!
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Jul 2014
    Evansville, IN
    72
    Thanks! What is used to raise cya? I looked over the website and couldn't find it. Many Thanks!
    38,532
    The answer lies within: Recommended Pool Chemicals
    Hint: it is cyanuric acid AKA stabilizer
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Trichlor and dichlor both raise CYA. They also provide chlorine, and lower PH.
    If you want only raise CYA you can buy it by itself. Usually sold as "stabilizer", just check the ingredients for it to say either cyanuric acid, or isocyanuric acid.. It is available in both liquid and solid (granular) forms. The liquid is easier to deal with, but costs more than the solid CYA. The solid CYA takes up to a week to fully dissolve. Usual method with the granules is to put it in a sock, and hang that in front of one of your returns.
    J.R.
    20K IG gunnite pool
    Cartridge filter
    Jul 2014
    Evansville, IN
    72
    Is it sold at Walmart or Lowes? Thanks
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    Yup, both of them have it.
    WalMart it is in the seasonal pool section and Lowes it is in outside garden with the pool stuff.
    Support the site
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Are you wanting to raise your CYA level for some reason?
    I manage my pool quite easily at a CYA of 30, and I get a lot of direct sun.
    J.R.
    20K IG gunnite pool
    Cartridge filter
    Jul 2014
    Evansville, IN
    72
    Not really, I just thought it might go down a little bit so I was going to raise it up. I'll leave it where it is. Thanks for all the help!
  20. Back To Top    #20
    Jul 2014
    Evansville, IN
    72
    Added Box of Borax per pool math and Ph went from 7.2 to 7.5. Should I try to get this to 7.8?
    FC coming down. 11.5 after 24 hours
    Cc is 0
    CH is 100. Do I do anything with this? I have a new vinyl liner
    Alkalinity is 170 ms hound I add a little muratic acid or let him come down over time
    Cya still 30
    Learning a lot. Thanks!
