Results 1 to 9 of 9
Thread: SLAM clarification
    Jul 2014
    Pittsburg, KS
    31
    SLAM clarification
    I'm in the middle of a SLAM right now...
    I've read through, and really enjoy reading all of the "Green to Glistening" threads on here. And I have read the SLAM procedure.
    My question is...
    In the SLAM procedure it says add chemicals to bring the chlorine level up to SLAM check and add as needed
    In the threads I've read several times that once the chlorine level drops 2ish (very scientific and accurate I know!) ppm below the Shock level then it severely looses it's effectiveness to rid the pool of the nasties.
    Would it not be better to shoot a little high on the chlorine level 3-5ppm or so, maybe a little higher depending on how fast it's depleted, so that the level doesn't drop below Shock level before you "rinse & repeat"?
    I know that too high chlorine level can have a negative effect on equipment, but at what level does that occur?
    Intex UltraFrame 14ft x 48in deep, 3,700 Gallon, Intex 14-Inch Krystal Clear 1,600 gph Sand Filter Pump, Taylor K-2006
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: SLAM clarification
    It's OK to overshoot just by 1-2 FC but more than that does accelerate wear on parts, especially vinyl liners. It's not a disaster to go 5 ppm more but there's no reason to go that high. There's no set rule on how much the FC has to drop before you add again. Just wait at least 30 minutes between addition, testing and the next addition. The more often you test and add during a SLAM, the faster it will go, keeping that FC near the target most of the time.
    Congrats on taking control of the pool... and I hope you have some before and after pictures?!?!
    Isolated Spa - 345 Gallons
    Quote Originally Posted by bull3299 View Post
    That is something of an exaggeration. People get a little too enthusiastic sometimes.
    When you are just starting the SLAM it is important to check and adjust the FC level frequently, preferably once an hour. As the process proceeds you can cut down on how frequently you check, but never less than twice a day.
    The recommended SLAM levels take into account how the process is written, i.e. that the FC level will fall before you get around to raising it again, and are the appropriate levels to target.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Within reason is fine. Vinyl liners need extra caution so that they aren't bleached out. We try to be extra careful with that. A few or so PPM over dose target so that you maintain target is a good thing.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I overshot by choice. Just pour bleach slowly or you will get fading on your liner.
    I would also change your gallons. The pool cannot really be filled to the full 48". I changed mine and measured at 15x3.5 ft deep and it worked better. So I would change yours to 4,000 gallons. I am sure someone can back me up on this.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jul 2014
    Pittsburg, KS
    31
    Thanks for the clarification!
    I did take a photo before, and couple during the process. I'll try to start a thread soon!
    Thanks!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Thanks!
    Looking forward to your progress.
    Lisa
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Same here on the gallons, different pool but same frame height. The height of my frame is 48" but that is not the depth of water. Mine is 3.5' and that is what I have found to be an accurate calculation. For me it is the difference between 7600 gallons (if the water was 48" deep) or 6700 gallons with the water being 3.5'.
    Happy SLAMming!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Jul 2014
    Pittsburg, KS
    31
    My wife and I went out the other night with a tape measure and got actual measurements!
    The pool is actually closer to 13.5 round filled to 3.5
    So, I was overshooting my chlorine unintentionally at the beginning!
