Results 1 to 7 of 7
Thread: stairs permanently in concrete!
    Sep 2014
    Bluffton/IN
    52
    Cant do much with a winter cover until these are removed. Suggestions on the removal of these steps?
    In-ground fiberglass hybrid (25K gal), Raypak Natural Gas, Hayward S-244S Sand filter, AquaRite SWG
    NE Indiana TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: stairs permanently in concrete!
    Please copy and paste the IMG links into your thread, not the URL. Every time I click the link you provided I get a bunch of pop up ads. I was only able to see one pic, but the pic I saw did not look like staining, it looked like cool deck or some overlay was peeling up.
    Feb 2014
    Upstate, NY
    390
    Perhaps a stupid question here? Are you sure they don't come out ??? It looks like a sleeve at the bottom of the rails. Use some force left to right to break the "seal" if you will.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Sep 2014
    Bluffton/IN
    52
    Not a stupid question at all and maybe I am make an assumption here. I have tried to pull up by hand with no success. It doesnt seem to want to move at all. If you look at the top post in the picture it looks as though someone tried at one time (I just bought the house) and bent the rail
    Feb 2014
    Upstate, NY
    390
    From the picture it sure looks like sleeves are at the bottom of the two rails. How about spraying WD 40 or equivalent at the bottom of the rails going into what look like the sleeves ?
    Sep 2014
    Bluffton/IN
    52
    I will give it a shot! Thanks
    How do you loosen the rails attached to the side wall?
    Feb 2014
    Upstate, NY
    390
    They usually just have rubber bumpers on the ends that wedge against the pool wall. "Free floating" if you will.
