Thread: No bottom drain. Any affect on a SWG???
    Apr 2015
    Southampton, PA
    4
    The bottom drain on my pool was filled in before I purchased my house. I guess it had a leak??? The only return have to the filter is 1 skimmer. Will this cause an issue with a SWG? I am afraid the salt could stay at the bottom of the pool.
    26k inground, Fiberglassed Concrete, CircuPool SJ-45, Gulfstream HE125Ra Heat Pump, Hayward Pump, Polaris 9300 Cleaner
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: No bottom drain. Any affect on a SWG???
    Welcome to the foruM!
    To answer your question, no, salt won't stay at the bottom of the pool. A MD is not really needed in a pool. Do you have more than one return and can you point it down into the deep end, or do you not have a deep end? Either way not a big deal.
    Mark
    Apr 2015
    Southampton, PA
    4
    I have 2 returns. One in the deep end is an eyeball pointed down. The One in the shallow end is a regular outlet.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Perfect. That is all you need?
    Mark
    Apr 2015
    Southampton, PA
    4
    Quote Originally Posted by mas985 View Post
    For now...
    Your Polaris should help keep the bottom water circulated. In addition, it's a good idea to brush the pool at least once a week.
    Support the site
