Results 1 to 9 of 9
Thread: dpd powder - slam
    anguspoe's Avatar
    Jul 2012
    Kansas City, MO
    23
    dpd powder - slam
    in the process of slamming my pool, got home after work and pool has lost its green look and now is a milky white color.
    went to test FC, got my water, scoped in some r-0870 and nothing. no change in color......???
    I'll post a full set of numbers when I get back to the house.
    Re: dpd powder - slam
    That normally means that the FC level is zero, though now and then that can happen if FC is very high and you didn't add enough powder. If you have an OTO chlorine test handy, that is the most reliable way to see if FC is really zero, or is actually high.
    anguspoe's Avatar
    Jul 2012
    Kansas City, MO
    23
    haha I brought it with me.
    my pH has been climbing very quickly as well. started slam last night and pH was 7.5
    38,237
    Your FC is 0ppm.
    Lower the pH into the 7s and then raise the FC back up to shock level.
    What is your CYA?
    anguspoe's Avatar
    Jul 2012
    Kansas City, MO
    23
    CYA 10-20. i could see the dot with the tube full. can I add while slamming
    38,237
    Yes, you should get the CYA up to around 30ppm so that you do not lose as much FC to the sun.
    I would add about 20ppm, in a sock and put it in the skimmer, and continue to slam assuming you are up around 30ppm. Then in a week verify the CYA level.
    anguspoe's Avatar
    Jul 2012
    Kansas City, MO
    23
    how long before I retest pH after adding acid?
    pool 17200
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Quote Originally Posted by anguspoe View Post
    pool 17200
    at least 30 minutes, but an hour is probably better (pump running the entire time).
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I prefer 1 hour for my testing after addition.
    Essential Links:
