Thread: Leftover Products, ok to use
    I have several products left over from the previous homeowner.
    1. Stablizied tablets ( I assume contain cya so I won't use)
    2. Aqua Chem 4-1 Granulated chlorine
    3. Aqua Chem 4-1 Shock
    Does anyone know how 2 and 3 will effect other readings such as pH, ak, CH, etc.?
    24,000 G, Sand, IG, Vinyl
    Re: Leftover Products, ok to use
    You need to figure out what they contain. 4 in 1 products have extra things in them, some of which are harmless (clarifier) and some of which can cause problems (copper). If you can figure out from the label what is in it you can get a much better idea of how good it is to use and what effects it will have on your chemistry.
    Jun 2008
    Tucson area, AZ
    I did a little bit of "googling." The aqua-chem chlorinating granules are trichlor, and the shock plus is dichlor. Not sure what else is in them. Anyway, both trichlor and dichlor contain CYA, which, as you already know, you have to be careful about using.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Thanks for the info. I think I will hang onto the pucks for use when I have to go away for a few days. Once my TF100 comes in, I'll have a better understanding of how much I can use them.
