Thread: Removing Spa Jets
    Jul 2014
    Belle River, Ontario, Canada
    12
    Removing Spa Jets
    Hi everyone,
    Does anyone have experience with a spillover spa with jets like these? Two of them are sputtering and shooting out air and I'd like to remove them to inspect, and maybe switch a few around to test. Pump has prime, and the rest of them are fine. I would gladly take thoughts on what may be happening here.
    I used to have a tool to remove them - it was a plasticky tube that had some tabs at one end. It somehow disappeared over the winter (or the company that opened the pool may have helped themselves to it!) I haven't had any luck finding a replacement tool either locally or online, but I may be hindered by the fact I have no idea what it's called to facilitate a search.
    The outer shell turns a bit each way to control the pressure, but then stops. Can I use a pair of channel locks to just keep cranking it? Or is that tool a necessity? I never removed the jets before so I'm not really sure exactly how it's done. It doesn't seem like there are tabs or anything like that to push in. Obviously I don't want to break anything by using brute force if there's a technique to it.
    Thanks for your thoughts!
    ~15500 gal (60000 L) IG Vinyl, built 2011. Spill-over Spa. SWG - Zodiac DuoClear. Hayward Super Pump 3/4 HP. Pentair Sta Rite Max-E-Pro Booster for Spa. Hayward Sand Filter. Raypak Heater.
    Mar 2015
    Huntington Beach, California
    28
    Re: Removing Spa Jets
    If you do a search for "spa jet removal video" you'll see quite a few. My Artesian Island Spa jets come out simply by twisting them fully counter-clockwise to the "stop", then adding a little more twisting past the normal "stop" and then pull (sometimes a lot more if some sand has gotten into them).
    https://youtu.be/ooaUUqd-Wmk
    2007 Artesian Island Spa, Bahama 52, 2 pump, 450 gallon, Serial# 75777, Build date 2/23/2007, on Bromine and Borates.
