Thread: Heating cost
    Apr 2015
    Chesterfield, mi
    62
    Heating cost
    thinking about trying to heat pool this weekend. temp should be 70 degrees each day, 55 at night. current pool temp is 55.
    Does math below make since/sound right?
    Total Gallons = 18500
    Wind Speed Average = 3.5 MPH
    Desired Temperature Rise = 20 degrees
    Heater BTU's = 200000
    Heater Efficiency = 80%
    Fuel Cost per therm = $.35
    Our calculations based on your information shown above are as follows:
    Total therms required = 38.53
    Time (in hours) to raise 18500 gallons of water 20 degrees = 19.26
    Time (in minutes) to raise 18500 gallons of water 20 degrees = 1155.79
    Cost to raise 18500 gallons of water 20 degrees in 19.26 hours @ $ .35 per therm = $13.48
    34x18 doughboy (desert springs) above ground. Has deep end, but don't know depth yet. Pool came with house (first season). 22in sand filter (250lbs sand)with 1.5hp two speed pump. Pentair MiniMax ch 200m heater.
    440 gallon Emerald spa. Currently a 3.6hp, 2 speed, 46y, 240volts motor. Changing to a 3hp, 2 speed, 56y, 240volt motor.
    Re: Heating cost
    That is all roughly correct. The real world is somewhat viable, so actual may be more or less, but that is a good ballpark number.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Heating cost
    Do you plan on swimming in 75F water? Also do you have a cover? Otherwise it might take longer. You could lose 0.25 to 0 5 deg per hour in heat loss without a cover.
    Mark
