Upgrading Pump
IRObot
0
Apr 30, 2015
4
Dallas, GA
Like many other I am upgrading my pump to a sand filter/SWG. I plan on cutting my liner for the new intake valves. My problem is I don't have any intex plunger valves and I don't want to pay $80 a pop for those. My plan was to use some PVC ball valves. I want to go at 90 degrees off the intake valve then connect the ball valve. Would something like this work? It looks like one end has 2" threads to accept the intake valve then an insert end for PVC then the PVC ball valve.
Elbow joint
Welcome to TFP!
Something along those lines is certainly possible.
Watch out when mixing Intex and non-Intex equipment. Intex uses non-standard connectors, which require special adapters to connect to anyone else's parts.
Ok somehow my post disappeared. I am upgrading to a larger sandfilter pump/SWG. I plan on cutting my liner. I don't have any Intex plunger valves and don't want to spend $80 a piece on them. What I want to do is create a 90 degree angle off the intake valve then add a pvc ball valve then connect it to my 1.5" flex tube that came with the pump.
Intake valve I assume with thread is 2" to connect my tube like normal. so can I use this elbow to connect to the intake?
Ok so you think the elbow might not screw into the intake?
