Thread: Sequestrant Question?
    May 2012
    Oconee, Georgia
    82
    I have been using ProTeam Metal Magic. I noticed at walmart that they have something called Clorox Scale, Metal and Stain control. It is about $5 dollars a bottle cheaper. What I don't know if this is as good or will it work. It doesn't say on the bottle what is in it.
    Clorox Scale, Metal and Stain Control MSDS
    etidronic acid (Aerosol)
    2809-21-4 10 - 30 %
    2-Butenedioic acid (2Z)-, homopolymer
    26099-09-2 10 - 30 %
    DOT
    UN number : 1760
    Description of the goods : Corrosive liquids, n.o.s.
    : (CONTAINS PHOSPHONIC ACID)
    Class : 8
    Packing group : III
    ERG Code : 154
    Does this mean anything to anyone?
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    38,301
    Re: Sequestrant Question?
    This shows the recommended sequestrants and what ingredient to look for: http://www.troublefreepool.com/conte...d-metal-stains
    That Clorox looks like it might have the right ingredient, but not sure if it would be as effective as the Metal Magic
    May 2012
    Oconee, Georgia
    82
    I had read that before posting HEDP that is says is recommended is Etidronic acid. I don't know if is confusing.
    Clorox Scale, Metal and Stain Control contains two active ingredients, one of which we recommend and one of which we don't recommend.
    Metal Magic contains a higher percentage of the recommended chemical, so I would go with that.
    May 2012
    Oconee, Georgia
    82
    Quote Originally Posted by JasonLion View Post
    Thanks that is what I needed to know. I knew you would chime in a some point. Thanks for the help!
