Thread: what do my tests tell me
    Mar 2015
    Naples fl
    25
    I just bought a test kid waiting for the one y'all recommend to come in. Can anyone tell me my findings? This is my first one.
    My ph is about 8.5
    Chlorine levels are perfect
    Bromine is 4.6
    Acid demand took 3 drops times 12000 gallons (added a 1/2 cup)
    Alkanility 130ppm
    Any advice will help. I'm sick of the pinch a penny.
    Thanks
    13000 gal IG
    Hayward pump 1 1/2 hp
    Hayward star clear plus filter system (DE)
    Attached spa
    Covered lanai
    38,284
    Re: what do my tests tell me
    What test kit did you get?
    Certainly does not appear to be one of the Recommended Test Kits.
    You do not have bromine in your pool.
    The only thing this tells us is that your pH is too high and should be lowered back into the 7s.
    A chlorine level of "perfect" is not very helpful. And to know what FC level is good requires knowing what your CYA level is.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Mar 2015
    Naples fl
    25
    I got one at home depot today. The chlorine WaS 2.5. If my ph is to high is that what the acid does to lower it?
    13000 gal IG
    Attached spa
    Covered lanai
    30,419
    You really have to get some basics out of the way. read "The ABC's of Pool Water Chemistry" up in Pool School. That'll tell you what each parameter we test for does and it will tell you the ranges in which they need to be kept.
    We are huge believers in testing and testing with a kit that will give you dependable results. There is another article in Pool School (Test kits compared) that can help you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    One more handy article for you to read in Pool School.
    TFPC for Beginners
