Thread: Hose bibb replacement on filter assembly
    Apr 2015
    oviedo, fl
    2
    I have a Hayward filter with a hose drain bibb at the bottom. It's leaking and needs to be replaced. When I try to unscrew it from the housing the handle hits the base and prevents removal. Is there some trick? I cannot imagine I need to take the handle off to remove it and the same on the new one to install?
    38,475
    Re: Hose bibb replacement on filter assembly
    Welcome to TFP!!!
    Filters do not come with hose bibs, so that is aftermarket. Is it that difficult to remove the handle first?
    Apr 2015
    oviedo, fl
    2
    Thanks. This is the Hayward filter assembly that installed brand new with the pool. It is hard to get at so I anticipate that trying to remove the handle off of the bibb will be nothing but a problem. It's so old that half of the handle broke off when I treid to close it tighter to stop the leak.
    38,475
    Well, then the builder must have added that valve. Maybe you will have to just break off the other half. There is no need to install a hose bib in that location. Usually it is just a plug. Although the valve allows you to direct the water when you drain the filter.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    What is the model number of the filter?
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
