Thread: Sta-rite multiport settings
    Jul 2008
    Solon, Iowa
    170
    I noticed that my filter has a 'Winter' setting on the multiport valve. What state does that put the valve in, and is it equivalent to setting the handle to an intermediate position for closing?
    Tx,
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    37,887
    Re: Sta-rite multiport settings
    The "winter" setting is the same as an in between position, it allows everything to flow to everything. Basically it is a way of making sure that the valve drains out completely and doesn't have some water left in one of the ports that could freeze and damage the valve.
    Mar 2007
    Coastalish 'down easter'
    4,160
    It also prevents the spider gasket (wagon wheel) from bonding to the key assembly and shredding the first time you turn it in the spring 8)
    Luv& Luk
    -Ted
    Jul 2008
    Solon, Iowa
    170
    Should I remove and lubricate the spider gasket anway (and store it out of the filter for the winter)? Also, after the filter is drained, do I leave the drain plug out for the winter (if so should I cover it so mice don't decide to winter out in there)?
    Thanks!
    Kinguni's Avatar
    Winnipeg, Canada
    144
    We probably have the same filter as you. Once the valve is set to "Winter" that's where it stays. We don't remove anything from the valve. Drain cap is left off and I store it in my skimmer basket in the shed so it's easy to find in the spring. I don't cover the drain hole. I think it would be difficult for mice to do anything there.
    Jul 2008
    Solon, Iowa
    170
    Thanks. I"ll probably do the same unless someone convinces me otherwise. That filter looks too cumbersome (heavy?) to drag inside for the winter. I'm also guessing that despite the "winter" setting it wouldn't hurt to remove the gasket and lubricate it at some point.
    Kelly
