Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Looking to install a SWG. How straight forward will the plumbing be?
    Dec 2014
    Rockville, MD
    78
    I currently have a pretty straight forward plumbing system. 2" piping, being sized to 1.5" to enter/exit equipment. The easiest place to put the SWG would be the diagonal pipe in the foreground. Are SWG's required to be installed in a certain orientation? How about the flow switch and a proper amount of straight piping before it?
    I'm also looking at upgrading the single speed Superpump to a variable speed pump. I am considering a A.O. Smith ECM27CU dry end replacement, but if the plumbing for the SWG is going to be involved, there is really no reason to only replace half the pump at similar prices.
    Pool: 40x15ft "Mt. Lake" shaped plaster IG (30k gallons with Borates)
    SWG: Circupool Si-45
    Pumps: Hayward MaxFlo VS (SP2302VSP) + Booster Pump for Polaris 180
    Robot: Kreepy Krauly 830 || Filter: Pentair Tagelus TA-60D (Sand)
    Test Kit: TF-100 (with Speed Stir)
    Feb 2014
    Upstate, NY
    390
    Re: Looking to install a SWG. How straight forward will the plumbing be?
    If the flow switch is before the cell you need a minimum 12 inches of straight pipe before a 90 (elbow). If you install the flow switch after the cell, you can add the cell in your measurement meeting the 12 inch minimum guideline. You would install the SWG on the outgoing run from the filter. If you had a heater, the swg would be installed after the heater.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Although very close to each other, the plumbing work for the SWG and the plumbing work for replacing the pump have no overlap, and be done/or not do completely separately from each other.
    Most brands of SWG will be fine on the sloped pipe, but a few brands require horizontal mounting.
    Dec 2014
    Rockville, MD
    78
    Quote Originally Posted by JasonLion View Post
    I am considering the "Circupool SI 45" or the "Hayward Aqua Rite 40K". Do you know the requirements of either of these units?
    Circupool says "ideal installation is horizontal", which is a little ambiguous. AquaRite is fine in any orientation.
    Dec 2014
    Rockville, MD
    78
    I really appreciate the information.
    Dec 2014
    Rockville, MD
    78
    I just looked at my setup again. Am I going to be in trouble if the intake to the booster pump is after the SWG? Will the increased chlorine significantly hurt that pump?
    Jul 2007
    Suwanee, GA
    528
    Mine is plumbed that way and has been running that way for 8 years.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Dec 2014
    Rockville, MD
    78
    I have a circupool arriving next week. I guess I get to go solar salt shopping now.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    I own a Circupool SI-30 +, according to my manual the cell can be installed either horizontal or vertical so, diagonal should be no problem. +1 what Donny said, the flow switch must be installed at least 12" after any elbows. Installing it after the cell will make sure you meet that requirement. However, they stress that the cell & flow switch must be installed after all other equipment. Installing a booster pump after your cell could cause cell or switch problems.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Dec 2014
    Rockville, MD
    78
    Aaahhh... just got my si-45 delivered. I was told that the cell was about 12" long. But after assembling the cell and the unions, it totalled 16".... 1" more than the 15" of pipe I have to work with. I'm now trying to figure out the easiest way to gain 1+" and not add too much extra plumbing resistance.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Cut off the straight pipe below the lower 45* angle and to the right of the upper 90* and replumb at more of an angle.
    38,305
    Or get rid of the angled pipe and just go up vertically all the way to the top and use a 90 over toward the filter pipe.
    Either way you are going to have to redo all the pipe coming out of the filter.
    Dec 2014
    Rockville, MD
    78
    I thought of doing it both those ways. I was even wondering if it would be beneficial to re-orientate the multivalve, but that would be significant work. Since "horizontal orientation is ideal" according tto the manufacturer, I might go with the increase the diagonal approach. Also, the return pipe entering the ground is a bit crooked away from the pad. The vertical mount might draw more attention to this defect. I think it's time to buy PVC, joints, primer, glue, and of course loads of salt.
    38,305
    Wait a minute, how are you going to make the diagonal longer? The fittings are 45, so you can not change the angle.
    Dec 2014
    Rockville, MD
    78
    I think the idea is to droping the 45 on the vertical lower, then extending the short pipe above the 90 and tweaking the directions of all three of the angles on the return to get it all to line up.
    DFW, TX
    24,497
    Yes, shorten the straight pipe between the T and the 45 and then tweak the angles of the two 45s and the 90.
    Dec 2014
    Rockville, MD
    78
    Well it's done. Went the vertical route, but used 1x 90 and 1x 45 to make the connection. When it came to dry fitting, I just wasn't comfortable trying to preserve the diagonal.
    DFW, TX
    24,497
    Yeah, that's great! Good work!
  20. Back To Top    #20
    38,305
    Looks nice and clean!
