Thread: Stain on top rails
    Jun 2013
    Pelzer,South Carolina
    30
    Stain on top rails
    We removed our cover last Friday and noticed that several of the top rails had stains on them.We used the same pool cover last year and did not have this problem . I have tried several things to remove them, CLR,chlorox cleanup, muriacid,has anyone else had this happen ,I don't think these are rust stains because our pool is made of resin, thanks
    I tried attaching picture but had no luck
    27' Swim n Play Mystic II 52" Extruded Resin 17,200 gallons
    Hayward E series high rate sand pump
    Hayward wide mouth skimmer
    Saltron Retro SWG
    Hayward Aqua Critter
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Re: Stain on top rails
    Have you tried a Magic Eraser? We actually got some deck stain on our top rails (also resin)and the Magic Eraser took it right off!
    ​Jennifer
    19k gal, 27' x 54" AG Aqua Leader Saltwater 8000 installed April 2014; Aqua Pro 19" Sand Filter System 1.5-hp Pump; Hayward Aqua Trol Salt Chlorine Generator System; Overlap Boulder Swirl Liner; Polaris 65 Turbo Turtle Automatic Cleaner; TF-100 Testing Kit
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    512
    We use Magic Eraser also...works great for us.
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
