Thread: Dumb question about solar blanket
    Jun 2008
    Patterson , LA
    does it matter if the bubbles are facing up or down?
    I never used one and just took ours out yesterday to try and get our temp up to around 86 from 81
    Tahitian 54" x 30' Round AG 23,000gl
    Sta-Rite 1 1/2 H.P 150 SQ. FT. Advanced MOD Media CartridgeFilter System
    50ppm Borate
    Liquidator 4 Gal
    TF-100 Test kit
    First time pool owner 2008
    BBB from the start
    New Brunswick Canada
    Re: Dumb question about solar blanket
    The bubbles need to be placed face down, this allows the heat to be distibuted into the pool water. You will be hard pressed to get a 5 degree boost from Solar Blanket only. One neat trick though, is to shut off skimmer, and pull water from the main drain, the water down there is cooler then the top
