Results 1 to 17 of 17
Thread: need help with new pump
    Apr 2015
    FL
    8
    Hey guys, I'm a fairly new pool owner and have to replace my inground pump. The pump that was installed when the pool was built is a Sta-rite Max-e-pro. It has a 2x2 port and I'm having a hard time finding a low cost replacement with a 2x2 port. I've got a couple of questions and appreciate any help you can give me.
    1. I assume that I can buy an adapter for the port to get a pump with a 1.5" port to fit the 2" union assembly. Is that correct? I'm having a hard time finding an adapter like that online.
    2. Can I use a corded pump without the cord somehow to connect it to my Goldline control box?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: need help with new pump
    The only pumps that come with cords are AG pumps. You need to be careful about using an AG pump on an IG pump because it won't work unless it is self priming. What pump are you looking at?
    Also, what is wrong with your old pump? It might be fixable.
    As for the adapter, you want a bushing and couplers like this:
    http://www.homedepot.com/p/DURA-2-in...1?N=5yc1vZbutx
    Mark
    Apr 2015
    FL
    8
    I was looking about an above ground pump apparently so I've found this Hayward Tristar that looks like a better pick.
    I'm not sure what's wrong exactly with the old pump but it's about 8 years old and it's pretty beat up at this point. I'm fairly certain it's dead. Here's a link to 2 pics. As you can see it's taken a beating from the FL sun and humidity.
    Thanks for the link to the adapter!!
    Apr 2015
    FL
    8
    I guess I'm not going to get away with paying less than $400 then. I found this Hayward Tristar that seems to be a popular choice and should be a direct replacement.
    Thanks for the link to the adapters!!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Your current pump looks fine to me. It might need a new motor but it is up to you.
    But unless you have a spa, the TriStar is probably way more pump than you need. Why do you need a pump that big?
    Mark
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Up front price should not be the only consideration when buying a pool pump, neither should a it being a direct drop in replacement for whatever was their before/originally. All too often pool builders give little consideration to the appropriateness of pumps, particularly on more turn key pool installations. Instead they go with what they can get cheap, and often have the one size fits all attitude so they can buy in bulk / carry less inventory. This typically means the pool owner ends up with a single speed pump that is often overkill for their needs if they do not have water features, etc. Often a smaller dual speed pump is more appropriate for many pool owners, and while more expensive upfront than a single speed pump, they can often make up for the price difference in short order due to savings in electricity. So if you tell us a bit more about your pool, we may be able to help you pick a pump that will save you money in the (not all that of a ) long run.
    Apr 2015
    FL
    8
    Quote Originally Posted by Isaac-1 View Post
    It's a salt water pool of about 9K gallons. My current system runs off a Hayward Goldine controller with a solar heater.
    If I were to replace the motor, is that a pretty easy fix? I've not worked with any kind of pump replacement previously. Something like this I assume?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    That looks roughly right, but you should be able to find one much cheaper, however without knowing the exact model of your current pump we can't guide you to a specific suggestion. Your solar panels make the choice a little more complicated as it helps to know how they are installed, how high above ground, etc. As to changing out the motor there are a number of youtube videos that you may find helpful on the subject, some are better than others, but most brands of pumps are fairly similar.
    p.s. if your pump is the 1 HP single speed pentair ae100 I suspect it uses a standard 1102 UST or B2853 motor available for about $140 new on ebay, and a bit more other places. (most likely a B2853)
    Apr 2015
    FL
    8
    Thanks for the help. This is the exact pump - Pentair Sta-Rite P6EA6E-205L Max-E-Pro.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Compatible Motors USQ1102 (be aware USQ1102 is different from the UST1102 I mentioned above) this is according to multiple sources online, so if wrong don't blame me
    mas985's Avatar
    Pleasanton, CA
    11,737
    They are different frames.
    UQS is a two compartment 48Y square flange - Two Speed
    UST is a two compartment 56J - Single Speed
    Mark
    Apr 2015
    FL
    8
    Quote Originally Posted by mas985 View Post
    So if the current pump is a single speed should I stick with the UST? Will my control box even support a 2 speed?
    You need to get a motor with a frame size that matches your pumps frame size.
    For most people the simplest way to setup a two speed pump is to have a manual switch to change speed, which is normally left in the low speed position. Then the timer/automation system remains exactly as it was before. The only common exceptions are if you have a spa, or a pool cleaner that runs off of the main pump. Then you need to timer/automation system to understand about controlling a two speed pump. Nearly all automation systems are able to handle controlling a two speed pump, though you may or may not need to purchase a two speed relay. Most timers need to be upgraded to handle a two speed pump.
    Apr 2015
    FL
    8
    I've checked and it seems that my pump uses a square flange as shown here. So I believe that this should be a good replacement. Can anyone confirm?
    The only difference is that it's a 3/4 HP pump vs the 1 HP I currently have. For a 9K gallon pool only, is the 3/4 HP enough?
    mas985's Avatar
    Pleasanton, CA
    11,737
    You can't put a smaller motor on a pump without changing the impeller too or the motor will fail.
    What about a two speed motor, it isn't that much and would pay for itself fairly quickly.
    http://www.inyopools.com/Products/00...acYaAnGp8P8HAQ
    Mark
    Apr 2015
    FL
    8
    There's a good chance we will be selling the house within a year so I doubt I would be able to make my money back in that timeframe. If I just went with the 1HP in that model it should be a direct replacement I assume?
    mas985's Avatar
    Pleasanton, CA
    11,737
    You want the USQ1102.
    Mark
