Results 1 to 7 of 7
Thread: Am I using the calculator wrong? AM I missing something.
    j_m_min's Avatar
    Feb 2015
    Houston, TX
    47
    OK, I drained the pool. CYA was off charts. Now CYA
    Here are my numbers:
    FC 2.8
    CC 0
    PH 7.1
    CYA 35.
    TA is good
    CA is 100, so low. I have some Cal hypo shock, and I was going to buy some cal hypo chlorine to get that up.
    My pool isn't exactly square, it curves in and out, but is 33 ft long and 22 ft wide. 3 ft shallow end 6 ft deep, So I am assuming it is about 25,000 gallons. The calculator says 24,400.
    It has been 2 weeks since the drain and I was running the chlorinator with dichlor pucks to get the CYA up and had a bottle of liquid CYA.
    I input ph at 7.1. It says put in 129 oz of Borax.
    I input FC at 2.8. It says add 45 oz of 8.25% bleach to get 4 FC.
    I put in 75 oz of the Mule Borax, one box.
    I put in about 80 oz of 8.25 HEB store bleach.
    Next moring FC is 3.0. PH is 8.0 (or maybe higher).
    Am I using this caculator wrong?
    Is there some trick to getting FC up and staying up? At this rate I will be needing to put in a half a bottle of bleach everyday. Is this Normal? That is like $11.50 in bleach a week.
    Thanks for the help.
    25,000 IG plaster pool. DE Pentair 60 gallons. Hayward pump with Single speed AO Smith 2.4 hp motor. Pool installed probably 20 yrs ago. Taylor water tesing kit.
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Re: Am I using the calculator wrong? AM I missing something.
    I typically have to add about 2-3 cups of bleach each day to keep my FC up. My pool sounds like its a bit smaller then yours based on your 25,000 gallon estimate and I use 12.5% bleach so I guess that sounds about right.
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Without knowing the TA, it would be hard to know what the pH is going to do. With zero TA, it only takes 23oz of borax to raise your pH that far. With 100ppm TA it shouldn't raise your pH much beyond 7.3.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Quote Originally Posted by j_m_min View Post
    FC 2.8
    CC 0
    PH 7.1
    CYA 35.
    TA is good
    Yes, you are using poolmath incorrectly. To calculate pH adjustments, it asks for a number for TA. "Good" is not a valid number. You might also be wrong on your pool volume. It will take some time and observation to get that figured. If you consistently overshoot or undershoot on dosage, your pool is smaller or bigger than you thought. Shave two thousand gallons. If you start undershooting, add 1000. You'll get it figured out eventually.
    Also, chlorine is a consumable item. Shop for better prices. Sometimes pool stores sell higher strength bleach that works out cheaper than clorox. My 16000 gallon pool uses about a quart of 12.5% per day. Your pool is almost twice as big and your bleach is weaker, so half a jug sounds about right. It needs to be fed every day, whether it's by adding bleach or generating it in place with a saltwater chlorine generator.
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Try seeing if a local pool store sells 12.5% liquid chlorine. I get mine from my pool builder. 5 gallons of 12.5% costs me about $14.
    j_m_min's Avatar
    Feb 2015
    Houston, TX
    47
    I couldn't remember the TA number off the top of my head. Left the paper at home. It is 100.
    j_m_min's Avatar
    Feb 2015
    Houston, TX
    47
    Just curious how adding 75 oz instead of 129 oz of borax shot it up so high?
