Results 1 to 10 of 10
Thread: One jet not working
    Apr 2015
    niagara falls, canada
    6
    One jet not working
    First time opening our three-year-old pool by myself. Everything seems to be good however one jet is not working . It is the deep end jet closest to the main drain. As well when I turn the pump to skimmer, the pressure drops very low . I can't see any leaks. Any ideas?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: One jet not working
    Welcome to the forum!
    Skimmer line probably has a clog in it. Try backflushing from the pump to the skimmer with the valve on skimmer only.
    Mark
    Apr 2015
    6
    I have a cartridge filter. (3 stage). How would I do that? Thx.
    38,524
    He means by using something like a Drain King and using a hose to push water backward from the pump to the skimmer.
    mas985's Avatar
    Pleasanton, CA
    11,742
    You open the pump basket and where the pipe enters, stuff a hose wrapped with a rag into the hole and turn on the water. Just make sure the suction valve is set for skimmer only.
    Mark
    Apr 2015
    6
    Ok, did that and a small amount of debris was released, however the other Jet is still not working. I put a couple of small leaves in the skimmer and they ended up in the pump basket, so no clog there. Could there be a clog in the line running from the non working jet to the main line?
    mas985's Avatar
    Pleasanton, CA
    11,742
    It would be very unusual to have a clog in the return line since is after the filter. The only thing that could clog a line is part of the plumbing that may have broken off but that is pretty rare. Did you have any plumbing work done recently? Also, if you did have a clogged return line, pressure would be higher than normal not lower than normal.
    But again, if the filter pressure is lower than normal, that indicates a suction side clog and if the pressure only drops when the skimmer is engaged, it has to be in that line. However, pressure will normally drop by a few PSI when shutting off one of the suction lines so is this something you remember seeing before?
    Mark
    Apr 2015
    6
    When I switch from main drain to skimmer the pressure drops a little bit but then quickly goes back to normal. My pressure has always been around 10 psi since we got the pool . It seems weird that two of the three Jets would work properly if there was a clog? We did have a very hard winter and I'm wondering if perhaps there was water left in the line and the pipe might have cracked ? Since it's buried you wouldn't notice a leak?
    Apr 2015
    6
    I solved the problem by accident! I was trying to see if the pressure from the other jets was normal, and I covered my hand over a jet. I guess it built up pressure in the non working jet and it started bubbling and then flowing. Whew. Thx for your help Mark!
    38,524
    I think I sometimes get a little air build up in my furthest jet that reduces the flow ... usually on low speed. The higher speed seems to clear it out. Glad you got it sorted
