Results 1 to 7 of 7
Thread: Combined Chlorine
    Oct 2008
    Yuma, AZ
    33
    Combined Chlorine
    Tested Pool 90 days ago (drop test)and combined chlorine was.5 which has been normal forever. Tested today 3 times (drop test) and each time the pink color got lighter after the first (or 2d) drop but stayed the "lighter" pink without changing to clear after as many as 20 drops of R-0003. Bad Test or Pool has gone to H_ _ _? Help would be appreciated.
    14,000gal IG Fiberglass pool with 850 gal spill over spa, Whisper Flo 1hp pool pump, Whisper Flo 2hp spa pump, DE filter, Zodiac Clearwater LM3 SWG, "Heat Siphon" Model SX5HP pool/spa heater, a water leveler and a Kreepy Krauly cleaner
    38,548
    Re: Combined Chlorine
    You have not tested in 3 months?
    Did you do a full set of test results? Post them up as they could help point to a problem.
    Each drop should have an impact on the color, so I suspect that "lighter" pink you are continually seeing should not count ... although it is strange.
    Oct 2013
    Iowa
    82
    Is the 20 drops of R-0003 a typo? If that isn't a typo, review the instructions for this test, you might have gotten rusty over the 90 days. Normally you add exactly 5 drops of R-0003, then count the drops of R-0871 to clear.
    20,000gal in-ground 16x36 sentry pools vinyl liner, Pentair sand filter, Pentair minimax NT heater, auto-cover, Polaris 280 cleaner.
    Oct 2008
    Yuma, AZ
    33
    Thanks to both of you for your response. dfahrion hit the (rusty) Nail on the head. Kept using R-0003 after the 5 initial drops to try and bring it back to clear. Using the right R-0871 after the 5 initial drops of R-0003 resulted the normal .5 CC reading. I not only made this mistake once but all three times in my previous testing! I do test daily for Chlorine and pH but I am able to do a complete Trouble Free test kit T-100 test only every 90 days because I have followed Troublefree Pools recommendations exactly for the last 7 years which has resulted in an amazingly stable Pool. Thought I would cover my stupidity with a righteous plug for this great website.
    38,548
    Oops, sometimes it is the obvious that we overlook
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Well this is a much better outcome than having a CC of 17373361475!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
