Thread: Air collecting in the filter
    Apr 2015
    Las Vegas, Nevada
    25
    Hi all,
    I am new member and new to the pools in general. We got house with inground pool and spa about 12 000 gallons. We have Pentair VS pump and sollar panels installed.
    It works good beside lots of air collecting in the filter during pump operation. For about 2 hours the air collected is may be half of the filter body /it starts to send air to the pool return/.
    Where I should start looking for air leak and what would be the reason for this problem?
    Thaks in advance for all the help!
    12000 gallons inground pool with spa, Pentair VS pump, Easytouch 4, Intellichlor 40, Pentair Clean & Clear CC420 cartridge filter, solar panels, TF-100
    38,359
    Re: Air collecting in the filter
    Welcome to TFP!!!
    Well, the issue must be on the suction side of the pump (between the pool and the pump). Make sure there is enough water in the pool and there is not a vortex in the skimmer. Check and lube the pump lid and drain o-rings. Those are the easy places to start.
    Check out this article in Pool School for more ideas: http://www.troublefreepool.com/conte...side-air-leaks
    Apr 2015
    Las Vegas, Nevada
    25
    The inlet pipe was not aligned good with the pump. After realigning it looks like the problem is solved
    Thanks
    38,359
    Glad it was an easy fix
