Thread: Input on cracks
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Input on cracks
    been in my house for a few months. we have an inground SW pool that was recently refinished, however the tiling along the top apparently was not. the tile runs from under the pool deck topping to about 6" down, about half and half with the water line. I have seen quite a few cracks running parallel with the deck along the top of the tile and also some areas of grout missing. I assume I need to get this corrected. Do I need to have someone come in and re-do all the tile and grout...or is there a product that I could use to replace some holes and fill/waterproof the cracks? the cracks are about wide enough to insert a house key into
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Input on cracks
    Can you post some pictures? there commonly is a gap there, and little plastic strips are used to cosmetically fill it. Missing grout isn't going to hurt anything, but you could fix it if it bothers you.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Input on cracks
    will try and grab some pictures tonight
    Dan
