Thread: 3-way Jandy Valve Question
    muzer66's Avatar
    Sep 2014
    Atlanta, GA
    5
    I have a few questions regarding the 3-way Jandy valves on either side of my CL460 cartridge filter. My system is basically set up like this:
    • MAIN DRAIN & SKIMMER (JV) INTO PUMP INLET
    • FILTER OUTLET (JV) INTO LWR RETURN & UPR RETURN
    UPR RETURN has a Polaris 360 hooked into it.
    Coming into the pump, what should the skimmer-to-main drain ratio be ? Should I have the main drain mostly (75%) closed off ? And what about coming out of the filter ? Should I have that at 50/50 ?
    12,5K gal. IG plaster ||| Pentair CCP420 cartridge filter ||| Hayward 2HP Super Pump ||| unknown pool age…installed in the late-80’s ?? ||| K-2006C FAS-DPD kit ||| Polaris 360 pressure-fed cleaning bot
    38,261
    Re: 3-way Jandy Valve Question
    There is no correct setting. Although usually it is best to have most of the suction coming through the skimmer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    My normal is about 80 skimmer 20 drain. Because I have trees dropping stuff in my pool. When brushing or if dusty I'll move it to 20 skimmer and 80 drain to suck more stuff down the drain.
