Thread: Using top rails to identify post locations?
    Jul 2009
    Near Annapolis, MD
    22
    I'm just getting started with my first AGP install (8'x15'). In reviewing other threads on how to get started, I noticed some people recommend assembling the top rail and use it as a guide for determining the site layout and where to place the paver blocks. Seemed like a good idea to me, so I start rummaging through my shipping boxes, and realize that this doesn't appear to be too easy. It looks like I would need to attach (w/ screws) each section of the top rail to the metal post top plate before installing the plastic top cap. Is this right? Seems like an awful lot of work, plus I would worry about flexing any of these connections since it wouldn't actually be installed on the post.
    Or is this method intended to work only for certain types of pools with easy to assemble top rails (of which mine may not be)?
    Apr 2014
    FOUR cORNERS
    111
    Re: Using top rails to identify post locations?
    It would help if you were to tell us what pool you have!!!
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    People assemble the top rail for Intel pools. Sounds like you have a metal wall oval pool. What you want to do is assemble the bottom wall track. Everywhere you connect two pieces using the provided hardware you will need a paver. This is where the posts will be when assembled.
    Jul 2009
    Near Annapolis, MD
    22
    Thanks for the info. In case relevant, the pool is an 8'x15' cameo from the pool factory.
    Feb 2015
    Bardstown KY
    139
    https://www.thepoolfactory.com/cameo-oval.html
    When people assemble the top rail first they are referring to Intex (or similar) - in our area they're called 'pop-up pools'.
    Good luck with your install!
    27k gallon 33' round, partially buried 22" Sandman sand filter, 1.5hp 2 speed TidalWave pump, Pentair 'Lil Shark with leaf canister, TF-100 Test Kit
