Page 1 of 10 1234 ... LastLast
Results 1 to 20 of 191
Thread: It's Pool Repair Weekend!
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    I'd like to use this as a "working thread" for myself and any other pour soul who has the pleasure of facing the feat we will this (long) weekend.
    Can a pool 40x20 concrete "vintage" (ha!) pool be repaired in a long weekend? Or I guess more appropriately worded would be how well can such a pool be refinished in a long weekend?
    Background - purchased a house in Fayetteville, NC (Ft. Bragg) from a "flipper." Soon thereafter, courtesy of the U.S. Army, we were forced to move to the DC area. House became a rental (that we lose money on every month and can't sell due to housing market).
    Had maintenance performed by professional year around until winter of 2014 when our pool man retired (after 30 years) due to health issues, and we let it go. We traveled to NC a few weekends ago and dumped a bunch of chlorine and algaecide into pool. Cleared up reasonably well, but may be green again by now.
    Pool Specifics;
    From what neighbors have told us, the pool is at least 30 years old. There is no main drain, no hydrostatic hole. No tile around edge. Nothing but concrete.
    Had pool pressured tested last year looking for leak that's not horrible, but drives up water bill about $10/m. Suspect leak is behind light (which was removed 2 years ago to fix, but never got done). Pool is plastered and was painted - who knows how long ago - and per the test done this week, it's plaster and an epoxy paint.
    Before buying house the pool cracks (minor) on floor were "repaired" by a flighty-handy man. Within a week of closing paint started chipping from plaster/mortar of these repairs. Other than that, pool was pretty and certainly swimmable so we lived with it.
    Fast forward 4 years and here we are. Plaster has started pulling away from walls at top edge and paint is chipping throughout, as well as chalking.
    Pictures to come.
    We realize the pool needs to be completely resurfaced, but quotes have come in for $10k and that's just not in the budget. We could likely venture a DIY replaster, but due to time constraints (living in DC) this isn't a viable option either.
    So we will venture down this weekend (Friday morning) to do whatever we are able to make the pool reasonable for our tenants within a few days, a budget of around $1,000, and the weather - starts raining this afternoon and stops early Friday afternoon, but doesn't appear to be a lot of rain. We are not looking for a 20 or 30 year fix. We hope to get perhaps 3 years from this weekend's fix to keep our tenant happy and our chemical expenses down.
    Before I start into questions about products to use, step 1 is to drain the (40k(?) gallon) monstrosity. I have someone local that can pick up a (rented?) sup pump for us and start the draining process. My immediate question is what specifications does the sump pump need to be? Besides being submersible, anything in particular we need to make sure the pump has/can do?
    We can buy this one from Harbor Freight for $40 (with coupon). Any reason this one won't suffice? http://m.harborfreight.com/16-hp-sub...gph-68422.html
    Or we could rent this one from HD for $42/day (or likely somewhere else for less). http://www6.homedepot.com/tool-truck...112/index.html
    We would be so incredibly grateful if some of you will help us along in our journey this weekend for the "temporary fix" for our pool which we have affectionaly named "Pita" (for PAIN In The *****). As I intend to provide pictures along the way, there's likely someone else in the future who will also benefit greatly.
    Cheers!
    38,524
    Re: It's Pool Repair Weekend!
    The HF pump will be a LOT slower than the one rented from HD. So depends on how quickly you want to get it drained. FYI, if you get a 4 hour rental less than 4 hours from closing time you get to keep it over night and return it the next morning. You could likely get it pumped out over night. I think it took me about 4 hours to drain mine, so you might expect 8 hours for yours with the HD pump. The HF pump might take a few days.
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    FYI, if you get a 4 hour rental less than 4 hours from closing time you get to keep it over night and return it the next morning. You could likely get it pumped out over night. [/QUOTE]
    Great info, thanks! But we likely will need it all weekend to pump out pressure wash and acid wash water.
    How about this? https://www.sunbeltrentals.com/equip...-level-intake/
    One thing I didn't mention, the distance from the pool to sewer is probably near 100 yards.
    20x40 in-ground concrete "vintage" pool
    Approx 35k gal
    Concrete, plaster and epoxy paint
    Sand filter
    DIY plaster resurface repairs completed 6/2015.
    38,524
    The bigger the pump the better ... especially if you are going to try to put it that far. I am not sure they will even give you 300 feet of hose.
    Mar 2012
    Tampa Bay, Florida
    166
    I hope the ground water table is low in your area. We could never drain a pool that big in our area without it popping out of the ground. We have to pull ground water out at the same we are draining and continue pumping ground water while working in the pool.
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Thanks for the heads up John.
    I keep seeing info on pools jumping, and it's a scary thought!
    Some say it's a concern, others say as long as there isn't a substantial rain, there's nothing to fret.
    I called the City and County today and spoke with 3 different departments. The first "engineer" I'd swear graduated last year from HS. The next dept I tried seemed to result in a seasoned gentleman, but he was clueless as to what my concerns were.
    A Google search resulted in access to maps that made very little sense to me. Is there somewhere I can go to perhaps search for an address and be given the history of the water table level in my area? (It's Cumberland Co, NC.)
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Now on to the critical items!
    As I said, we aren't expecting a 30 year fix with our repairs. We don't mind if there are rough patches. We merely need a short-term solution to uphold what's left of the structural integrity of the pool.
    If I knew of a paint type substance that would essentially seal any exposed concrete and cracks, we would likely just chip out what's lifting, acid wash, power wash, and then paint. (If you know of such a substance, please pass that long to me.)
    With our timeline I think our concentration should be on repairs and patches and on acid washing. So, we need a plaster patch material that has a short cure time. I'm thinking a type of plasters that can be used under water would be best. Anyone have experience with a good product that won't break the bank?
    Am I right that it would be best to use a high quality patch product and skimp on the quality of paint/coating?
    My only two cents, as a contractor, not pools electrician, everytime I bought anything from harbor freight that has a motor, burns up real quick. I doubt u will be drain pool often, I would rent a good pump n skid anything from harbor freight unless is a basic hand tool.
    Using Tapatalk
    Mar 2007
    Virginia Beach
    272
    If you are looking for cheap waterproof paint patching, look at Drylok. Latex based and lasts pretty good. Might get a year our of it.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Quote Originally Posted by greg.stevenson.90 View Post
    Turns out our neighbor there has one. He's hooking it up this morning for us, which also affords us one less day of a hotel room. So at this point, we're up by about $150.
    He's also agreed to help us this wknd. (We'd rather pay him than some unknown day labor person.)
    Approx 35k gal
    Sand filter
    Dec 2012
    Manassas Park, VA
    207
    When I drained my pool I also found it impossible for anyone to tell me the water table in the area. I purchased a post digger from HD and dug a hole the depth of my pool (about 5 1/2 feet). I let it sit for a day and checked to see if there was any water in it.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Quote Originally Posted by Rocco View Post
    Unfortunately, our pool is 10' deep. But I like your means for future info! Tks!
    Approx 35k gal
    Sand filter
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Quote Originally Posted by keithw View Post
    Looking at it now online. And might very well be our answer! What will happen when this stuff starts breaking down? Paint chips, cloudy water ?????
    Approx 35k gal
    Sand filter
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by Household6 View Post
    SCS Soils Survey.
    http://websoilsurvey.nrcs.usda.gov/app/
    Click on the green button that says "Start WSS". then search by address. then use the button called "AOI" near the top of the screen and create an area of interest over your property (nothing exact, just close). then click on the tab at the top called Soil Map. you should see a clickable blue text for your soil type. pulling that up, go down to the category called "properties and qualities" and you will see it listed as "depth to water table".
    hope this helps people. its not going to be exact but gives you an idea if you are 12" from the surface (like me) or 12 feet. ballpark
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Quote Originally Posted by DaninFLA View Post
    SCS Soils Survey.
    This sounds like EXACTLY what I need!
    Thanks!
    Approx 35k gal
    Sand filter
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Yall ready for the pictures?
    I must admit, it's worse than I remember.
    Approx 35k gal
    Sand filter
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Approx 35k gal
    Sand filter
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Approx 35k gal
    Sand filter
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    We leave tomorrow (Friday) at lunch (EST) for the 6 hour drive to our pool. Anyone have any suggestions for a packing list or tools list of items that will be needed?
    Here's what we have thus far on our packing list:
    Wet vac
    Electric Hand sander
    Hammers
    Chisels
    Electric drill
    Flat head shovel
    Long level
    5 gallon buckets
    Trash bags
    Step ladder
    10' ladder
    Painters tape
    Screw driver set
    Gloves
    Tarp
    Trowels
    Putty knives
    Tape measure
    Roller frames
    Rags
    Paper towels
    Old clothes
    Old shoes
    Heat gun
    Bug spray
    Sun screen
    Items we will be renting or purchasing in area:
    3500 psi pressure washer
    Floor sander
    Orbital hand sander(s)
    Sandpaper
    Sump pump (already rented and pool is currently draining)
    Kitchen broom
    Long broom
    Paint rollers
    Paint brushes
    Stir paddle for drill
    Wheelbarrow
    Ramp
    (Considering dynamite JIC we get discouraged.)
    Any additional thoughts or suggestions?
    Approx 35k gal
    Sand filter
  20. Back To Top    #20
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Thanks!
    cool, hope it helps
    Dan
