Thread: Dolphin Oasis Z5 - 4 ppm Max Chlorine - Is this Unreasonable?
    Apr 2015
    Lubbock, TX
    9
    We recently purchased a Dolphin Oasis Z5, and the warnings instruct us not to use it when FC exceeds 4 ppm. This seems unreasonable to me, especially when our pool has CYA of 97, necessitating a higher minimum of FC to prevent algae.
    (We just moved into our house and are first time pool owners. At the start, our CYA was 140, so we are making improvements...)
    Does anyone have any insight as to whether it would be okay to use our Z5 at higher levels of FC? Obviously, we won't put the Z5 in the pool while SLAMing, but 4 ppm just seems like a very low tolerance level for a pool cleaner.
    17,500 IG plaster, attached spa with spillover, Hayward Heat Pump 350k BTU, Whisper Flo 1.5h, Sand Filter, FAS-DPD 81329
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Dolphin Oasis Z5 - 4 ppm Max Chlorine - Is this Unreasonable?
    It goes along with the traditional recommendation to keep FC between 1 - 3 with no regard to CYA level.
    I ran my M5 all lat year with 200+ CYA and FC in the 20 range. He is out in the pool right now cleaning......
    My normal FC is 6 now, so i guess I'm still above their recommendation.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    Right down the road from you here..
    Tim has you right. Pool equipment people simply can't go outside EPA guidelines, which unfortunately don't recognize Cya residuals. No worries though, my M5 never sees 4 except when I slip on my duties. He's seen anywhere from 6 up for a year now, and no problems. I truly don't believe slam levels would hurt him, but extended periods of that probably aren't adviseable.
    Good to have you aboard, and I'm glad you joined us.
    Essential Links:
    Apr 2015
    Lubbock, TX
    9
    Thanks for the responses!
    May 2014
    Franklin, NC
    9,193
    Anytime!
    now we need a photo of your pool
    Support the site
