Thread: Gas Line for Pool Heater
    Mar 2015
    Rexford/NY
    4
    New at the whole pool thing. I had our pool installed late in the fall last year, so this will be our first full year with it. Looking for some info on gas line to heater. Any info on where I can buy 200 feet of 1 1/2 PE gas line. The suppliers in my area only have 150 and 500 foot rolls. I don't want to put a splice under ground.
    Thank You,
    Pete
    18x29x35 (In-Ground) Lagoon Cardinal Steel Pool 25K Gallon
    Hayward Pro Series High Rate Sand Filter Model:S2446
    Hayward Super Pump Model: SP2607X10 1HP
    Hayward Natural Gas Heater Model: H350FDN
    ps0303's Avatar
    Jul 2011
    FL
    3,682
    Re: Gas Line for Pool Heater
    If you do a Google search you should find some online companies that sell this.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Feb 2014
    Upstate, NY
    390
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    38,242
    Welcome to TFP!!!
    I would think if you have the proper tools to install the gas line, then a welded splice would be no big deal.
    This is not really a DIY project IMO. Or are you just digging the trench and laying the pipe?
    Dec 2009
    Central Massachusetts
    2,690
    They make heat fusion tools to join PE gas lines. We used to use the tools that you heat up with a torch. The pipe goes on one end, and the fitting on the other end of the tool. Heat it up with a torch, the pull the pipe and fitting off the tool, then put the fitting on the pipe. Now they have electric tools instead of having to use a torch. It's called a McElroy fusion tool. It basically forms a melted joint. It has to be pressure tested and inspected before the ditch is filled.
    And I agree. Not really a DIY job when it comes to running gas lines.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mar 2015
    Rexford/NY
    4
    I'm just digging the trench and laying the pipe. My contractor will do the rest. The pipe is coupled via a coupler using a chamfering tool. Town needs to inspect and pressure test.
    Thanks
