Thread: Check valve required?
    jccams's Avatar
    Dexter, MI
    95
    I am going to remove a leaking tablet feeder from my pool plumbing (don't use it anyway). Currently there is a check valve between the feeder and the heater I assume to prevent high concentrations of chlorine from reaching the heater. My question is whether or not I need the check valve in this location any more since there will be no chlorinator.
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    Re: Check valve required?
    Unless you have a solar heater, you can remove the check valve.
    jccams's Avatar
    Dexter, MI
    95
    Quote Originally Posted by JasonLion View Post
    Just a good ole gas heater, thanks Jason that's what I thought.
