Thread: Corrosion Concerns?
    tcook310's Avatar
    Apr 2015
    Norfolk,NY
    1
    Corrosion Concerns?
    I am serioulsy considering installing a SWG system on my 27' Radiant Metric Pool that I installed (inground) last spring. Pool walls are aluminum with a double layer acrylic coating. The manufacturer (Radiant Pools) claims a lifetime warrantee on the pool. Can anyone advise if a SWG/salt will corrode my pool walls. I've read many mixed reviews on multiple sites. I want to install the SWG for the convienience of it, but also don't want to damage the pool. Thanks.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Corrosion Concerns?
    Welcome to the forum. With aluminum walls and a lifetime warranty you should be just fine. I would be far more concerned with the fact that it is buried than the SWG. Very few issues reported on this forum using a SWG on an above ground pool.
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    I have been in the aluminum boat industry for over 20 years(18 as a fitter) and yes sea water can corrode unpainted aluminum. Sea water has way more salt in it that you will in you pool. Plus with a double layer acrylic coating on top of the aluminum, corrosion from the water is not going to be a problem.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    May 2013
    Albany, NY
    59
    Hi tcook310, just so you're aware, we've got hundreds of pools out in the field matched up with a SWG and haven't seen any issues with corrosion / oxidization. Use of a SWG will not affect the warranty in any way. PM me if you have any questions specific to your particular install. Thanks!
    Eric Adams, Technical Specialist, Radiant Pools
