Results 1 to 7 of 7
Thread: My first completed slam here are my readings
    Apr 2015
    Mesa, AZ
    13
    So now I maintain?
    Readings:Target
    FC: 4:6
    PH: 7.8:7.6
    CH: 475:Need to retest
    TA: 120:120
    CYA: 50:50
    Im in arizona to the CH test maybe just what it is, after i filled it it was at 375, had to add stabilzer, acid, etc. Now to the questions. I should raise my chlorine and i was looking at lowering my acid to the middle of the range but then I read with high CH then the acid should be in the 7.8?
    17k IG Plaster pool (2004), Pentair V3050 Intelliflo(2015), Hayward C3030 325cf cartridge filter
    Zodiac G3, TF-100 test kit w/ SpeedStir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: My first completed slam here are my readings
    Yes, bring he FC up. You will loose some to the sun each day and 4 is the absolute minimum you should have with CYA 50.
    As you suspect, keep the pH a little higher with the high CH
    Support the site
    Apr 2015
    Mesa, AZ
    13
    yesterday night it was ch was at 5 or 4.5 dont remember off hand. Also worth mentioning is CSI is .38 with a recomneded .18 dont know if that's good or bad.
    May 2014
    Franklin, NC
    9,184
    I'm going to keep from embarrassing myself and let Jason, Richard or one of the other guys out west with higher than normal CH jump in.
    Support the site
    38,262
    With high CH, you need to keep the pH a little LOWER.
    Yours is really not high enough yet to worry about that though.
    Apr 2015
    Mesa, AZ
    13
    Like 7.6?
    38,262
    Sure. Check the CSI, anything within +/- 0.6 is fine.
