Thread: Just Opened pool Chemicals
    Apr 2014
    Upper Chichester, Pa
    60
    I opened pool and balanced attempted to balanced Chlorine with Bleach method and now have
    FC 7
    CYA 50
    TA 90
    PH 7.5
    Should I leave this alone now????
    Sharkline Reprieve 21' x 52" Round Above Ground Swimming Pool, Waterway 520-5220-6S ClearWater 19in. Sand Filter Above Ground Pool System with Hi-Flo Single Speed Pump, using BBB method and TF-100 kit
    38,521
    Re: Just Opened pool Chemicals
    Yup .. until tomorrow when you need to test the FC again and add more bleach. Never let the FC drop below 4ppm.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    FC needs to be maintained so that it never drops below the minimum level for your CYA level based on this Chlorine CYA Chart
    30,432
    What does your water look like?
    Apr 2014
    60
    awesome I did my first season pool opening! water is crystal clear. we had a few leaves in bottom when I opened it but that was it. This is only my 2nd year with the pool and last year we struggled with algae learning because even with the expensive kit I wasn't testing the FC. I was using that other little kit that came with it. so I wanted to make sure I was right with the chemicals. Thank you so much.
    DFW, TX
    24,514
    Congrats on the successful opening!
