Thread: Does Calcium Hypochlorite raise CYA??
    Feb 2014
    Upstate, NY
    390
    I just drained my pool a little in an attempt to lower my CYA. Does Calcium Hypochlorite raise CYA ??? I have 2 packs left of the Robarb Pool Specialties "Power Blast". Ingredients state Calcium Hypochlorite 68%, other ingredients 32%.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    awtrizzle's Avatar
    Apr 2015
    Chesapeake/ Virginia
    295
    Re: Does Calcium Hypochlorite raise CYA??
    Calcium Hypochlorite does not raise CYA. Triclor would from Chlorine Tablets but Cal-Hypo does not.
    16k gallon IG, Hayward Super Pump, Polaris Booster Pump, Hayward DE filter, 2 skimmers and a main drain?, 4 returns that I can see, Vinyl liner w/aluminum coping
    14.5k gallon IG, Vinyl Liner, Hayward SuperPump (1HP 220v motor), Hayward DE Filter
    Polaris Booster Pump, 2 skimmers and one bottom drain, 5 returns.
    ~My Tremendous SLAM thread~
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    No. But it will raise the CH. Since you have a vinyl pool, the CH wouldnt be a problem unless it got exhorbitantly high, at which point you stand the risk of calcium precipitation.
    Quote Originally Posted by Donny View Post
    Divin Dave,
    Feb 2014
    Upstate, NY
    390
    Thanks everyone. I will wait till I see what my numbers are before adding it. Thx again.
