Thread: Support for Tile counter overhang
    Going to start my ODK build and am trying to visualize the tile countertop overhang. The countertop will be all one level, about 34 inches wide with a 24 inch base so about a 10 inch overhang for seating.
    How do I need to support the overhang? Would 1/2 inch plywood and 1/2 inch hardi provide enough support or do I need to frame some support for it?
    Also how do I mount the electrical boxes to stick out 1.5 inches? Going to rock the sides so need the boxes to stick out some.
    Thanks
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Support for Tile counter overhang
    I would think that with a 10" overhang the plywood & hardi backer would have a little too much flex. Add a couple corbels?
    Support the site
    4knights's Avatar
    NE Kansas
    419
    Don't forget the weight of people's elbows as the lean on the edge, some try to sit on the edge or just "rest" their butts on it. A lot of added weight. I'm currently building mine and am going to use doubled steel studs sticking straight out and then add angles or corbels for the needed support. Like the image here: http://perfectdesignpatios.com/outdoor_kitchens
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jan 2013
    Friendswood, TX
    320
    The overhang definitely needs supported. You could use metal t bars to try to discreetly support the weight. How long is the counter?
    As for the boxes, I set mine in the stone. They are mortared in place.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
