Thread: Stained plaster
    Noorm's Avatar
    Apr 2015
    San Jose, CA
    20
    Stained plaster
    Attached photo's of pool walls after brushing of what I believe to be mustard algae.
    Will these require acid wash to remove?
    In ground concrete/plaster. Re-plastered 5 years ago Approx 30,000 Gal.
    Hayward 2 speed pump and C3030 cartridge filter. Taylor K-2006 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Stained plaster
    If it is Mustard Algae, Chlorine is the answer. It looks like it could be regular Algae, but in either case a SLAM is in order.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Stained plaster
    Time to read up on SLAMing Your Pool
    Noorm's Avatar
    Apr 2015
    San Jose, CA
    20
    Re: Stained plaster
    Quote Originally Posted by pooldv View Post
    Oh, I've read up. Problem is my CYA is so high that the SLAM requires mucho CL, so I'm gonna try the BioActive CYA reducer first. (After I get FC down. LOL. Vicious circle.)
    DFW, TX
    24,502
    Re: Stained plaster
    Not interested in buying CL by the truckload eh? Good lucķ!
    30,426
    Re: Stained plaster
    Noorm,
    If that's a pic AFTER you brushed the walls, that is probably not any type of algae but rather calcium scale or iron stains.
    You must identify the stain positively before you embark on a plan to get rid of it. Is it rough to the touch?
