Results 1 to 8 of 8
Thread: Hello from Midlothian Texas
    Apr 2015
    Midlothian/Texas
    3
    Just found this Forum today, couldn't wait to sign up.
    I will be starting the build of my new pool shortly. I am going to do it myself so it may take a little longer.
    Just received the engineering drawing
    Pools going to be in-ground, gunite, with spa. 130' Lineal Feet, 23'X41'. I've got lots of land and need to fill it up.
    I went with mostly Pentair and the Pentair easy touch system.
    Should be a fun project, if anyone has any subs in the DFW area I would appreciate the recommendations.
    I'm looking for all the trades, plumber, electrician, rebar, Tile and coping, Plaster.
    Bob
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hello from Midlothian Texas
    Howdy Bob,
    Welcome aboard! I don't think you'll find many subs here, but maybe a lead. Good luck on your project.
    Essential Links:
    38,303
    Welcome to TFP!!!
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Welcome to TFP-can't wait to follow your Pool-build!
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Jan 2013
    Friendswood, TX
    320
    Hello!
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Don't know of any subs, but wanted to welcome you to the forum!
    Apr 2015
    Midlothian/Texas
    3
    Thanks everyone. As soon as I get started I'll start a post with pictures in Under Construction.
    Due to all the rain excavators are at least one month behind schedule. I've already learned a ton just from the day I've been a member.
    Casey's Avatar
    SW PA
    10,448
    Welcome! Looking forward to your build!
