Thread: How To Repair Fafco Sungrabber Solar Panel?
    I'd like to hear some suggestions as to how to repair leaks while still allowing the flow of water? Their Plugs just disable the tube, would rather use something that still allows the water to flow.
    Located in Ottawa, Ontario Canada
    23K Gal, AG, Cart filter, 1.5hp 2speed hay PowerFlo Matrix, Install Sum'13, Aquatrol SWG, Solarbear panels, kreepy Krauly E-Z Vac, TF-100
    Artesian ~500gal Grand Gayman Island Spa
    Re: How To Repair Fafco Sungrabber Solar Panel?
    Fixing a leak in one of the small tubes without blocking the tube is very difficult and tends to just fail again. Leaks should be rare enough that blocking a tube here and there does not cause any issues.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    what Jason said.
    Blocking a tube shouldn't have much if any of impact.
    I found 2 leaking tubes on 2 different panels on my roof this past weekend and repaired them
    with 1/4" nylon bolts with the head cut off and some liquid nails silicone adhesive. easy.
    one of them was "repaired" without blocking it. someone had used a jb weld type goop on
    the tube covering it....it was leaking. After repairing it the proper way with a plug it doesn't leak at all.
    Dolphin E10 Cleaning Robot.
    Quote Originally Posted by borjis View Post
    what Jason said.
    I was thinking of maybe getting 1/4" I.D. tubing (the kind used for garden irrigation) and pvc gluing it over the area leaking. I think 1/4" might be the right size? I would have to cut the tube from the panel so it is not connected on sides and is individual then just cut out leak, apply glue slide into tubing, same on other end.
    That should fix and not leak
    Costs about $9 for 50ft of tubing
    38,463
    PVC glue will not really stick to the type of plastic that the solar panels are made out of ... nothing really sticks to it, thus the need for mechanical repairs.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Maybe you can buy a spare panel and use tubes off of it to repair the ones on the roof. Does the company sell spare tubes so you wouldn't have to cut tubes off a panel?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
