Thread: Milky haze on Flagstone
    Unhappy Milky haze on Flagstone
    I have a Saltwater Pool. It's ~10yrs old. We have owned the house for a year. Chemicals have always(well mostly) been in balance.
    Just in the past few weeks I noticed this white haze around the spa.
    I am assuming the flagstone is not sealed.
    Any idea what could of caused this? It's a pretty drastic color change and seemed to just appear. It certainly wasn't there last year and did not seem to gradually color.
    I have read that washing with Muriatic Acid should clean it off.
    Thank you in advance!
    Attachment 35741
    Re: Milky haze on Flagstone
    Does water tend to splash onto there? That looks like minerals left from evaporation. However, I can't think of anything that would cause that to appear suddenly, unless water just started constantly spraying onto there.
    Quote Originally Posted by JasonLion View Post
    Thank you for your prompt response. I am sure it wasn't an overnight thing. It's on the far end of the pool and I just noticed it one day.
    What's the best way to acid wash a small area? A disposable spay bottle and a brush?
    Feb 2014
    Upstate, NY
    390
    A natural bristle brush is what I would use and dilute the acid with water. 4 parts water to 1 part acid at first is my recommendation. Go from there.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Sep 2014
    Wharton County, Texas
    32
    If you spray a little muriatic acid does it bubble? If it does use the mixture above with a brush. I had a calcium build up and a wire brush and muriatic acid was the only thing that took care of it.
    19K gallon free-formed w/ 60% Color Quartz plaster
    3.5' x 5.5' x 4' depths - 15' x 20' 15' widths - 12" oval raised spa with spillover
    Hayward 1.85 hp TriStar VS Pool & 1.25 hp water feature pump - Cartridge Filter
    Hayward OnCommand automation system - 400K BTU heater - LED lights for pool & spa
    20' weeping moss rock wall - 5' x 8' tanning ledge with bubbler
