Results 1 to 9 of 9
Thread: Grey Plaster or white??
    I like the way the dark blue water looks from grey plaster, but then i like how clear blue water looks when clean with white plaster.
    I know that a white plaster will be better for SPECTRUM AMERLITE lighting. With grey plaster , i may have to add more lights.(17X32 6 FOOT DEEP END POOL)$$$.
    I know that i will have less glare from a darker plaster, this is what is pushing me to get grey plaster for darker blue water.
    Any advice on which to choose and why..
    I LIKE THE WAY THIS POOL LOOKS GREAT JOB WATERBEAR!!
    waterbear-s-pool-pics-t167.html?hilit=POOL%20PICS
    18K gallon IG pool and separate 1200 Gallon IG spa - Both have: Diamond Brite Plaster- Hayward DE Filter -Propane heater- renovated 8/2008
    Re: Grey Plaster or white??
    You already seem to have a good idea of the primary issues. One secondary issue is that calcium scaling shows up rather obviously on gray plaster, while it is often nearly invisible on white plaster. Proper chemical balancing can prevent calcium scaling from ever occurring, but it happens often enough despite that.
    You have a tough decision to make! Ours is white, our neighbor has grey. I like his water color better, but don't like the mottling he has. I was told to stay away from grey for that reason. I can be obsessive about uniformity of color, so PB said I had to have white, LOL. It's a clean, classic look and it's very pleasing to me *most* of the time. There are a few times depending on the light when I'll look out and say "We should have gone darker on the finish".
    No Cover Charge
    17,000 gal IG w/ raised 8' spillover spa, 3M plaster, 10' stainless rain WF, Pentair SAM lights, Sta-Rite Sys3 cart. filter, Intellichlor SWG, 400kBTU Gas Heater, Paramount IF Cleaners, ET-8 Wireless Remote
    Quote Originally Posted by Vegasmom
    What is mottling? what exactly does it look like? Photo's would be great..
    We have medium grey and love it the water color. Mottling is the marble-like differences in the final product. The grey plaster goes on a uniform color, but when the water is in and everything is done, it is not a uniform color. I will say that if our PB told us that the color differences would be so dramatic, I'm not sure we would've picked it. However, now that we have it, we really like it and the neighbors complement it too. Obviously the differences in color are more dramatic on the ledge, steps and shallow end. You do notice it in the deep end, but it's less pronounce.
    15K gallon gunite pool and spa spillover - medium gray plaster, 2.5HP Hayward pump, Cartridge filter, Goldline Aquarite SWG, Jandy RS8, Polaris 280
    mas985's Avatar
    Pleasanton, CA
    11,640
    I decided to go with white because I like the lighter blue color. If you like the darker color you might consider some of the other finishes such as Pebble Tec, Fina, etc. or even Quartz. I think these produce a more uniform color finish.
    Mark
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    With my pool white and a friend's pool grey, I can see than his pool stays 5 degrees warmer... must be because of the darker finish absorbing the sun rather than bouncing it out of the pool.
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    Will mottle on grey plaster ever go away?
    I did some reading and understand the idea of why mottling takes place.(Parts of the plaster dry differently than other parts, giving the kind of light and dark areas).
    Back to my question , is this permanent or will the darker areas lighten up over time? I was reading that when filling the pool after plastering where the water is introduced into the pool, is where most of the mottling will take place.(Putting the hose in the deep end causes more mottling in the deep end of the pool).
    I have read different ideas on grey plaster and why mottling takes place. Some say different drying times, others say the mixing of the plaster. Nevertheless, mottling is something that is just part of having a darker plaster. It is very difficult to control when applying plaster.
    I spoke to a PB that said, that if chemicals are kept up correctly the mottling will be less over time??
    Has anyone that has had grey plaster seen the mottling dissapear over time?
    What is the correct method of introducing water into a new pool to reduce mottle, if at all?
    mas985's Avatar
    Pleasanton, CA
    11,640
    Mottling tends to get worse with time and even happens on plain white pools as well. Take a look at older pools and you will see a big difference. It is just starting to happen with mine but because it is white it is very difficult to tell. It is just the nature of the beast.
    Again, there are other surfaces than plaster which are better suited for color. Quartz is not that much more than plaster and will not mottle as much.
    Mark
