Results 1 to 20 of 20
Thread: Very Low FC, Very High CC
    Apr 2015
    Long Valley, NJ
    7
    I became a first-time pool owner when we purchased a home with a pool a couple of months ago. I'm in northern NJ and I hired a pool company to open it 10 days ago(mid-April). It is a 35,000 gal in-ground gunite pool. They put some 3" Tri-chlor tablets into the automatic feeder and 10lbs of Sodium-diclor into the pool as shock and also added an algaecide. The pool has a pressure DE filter. The floor of the pool was covered with a fine silt. I vacuumed and brushed it up several times and the filter required backwashing every day for a week. I was testing for Free Chlorine and was not getting a level so I shocked the pool 2-3 times using Sodium Di-chlor following the package directions (~4lbs per shock). Still very low FC. I brought a sample to a pool store and they found that my Total Chlorine was 7 and Free Chlorine was 0.8. All the other measures were fine (pH, stabilizer, alkalinity, etc.). I have stopped adding chlorine because I think I'm only making the problem worse. The water is looking pretty clear at this point with only a little bit of the silt left. Can you guys provide any advice? Will the Combined Chlorine drop on its own over time or do I need to do a massive addition of Chlorine? Weather is still cool here so we don't plan on swimming for 2-3 weeks. Thanks.
    Re: Very Low FC, Very High CC
    Welcome to TFP!
    Your first issue is that all of that dichlor is raising the CYA level very quickly. CYA is going to get way too high soon, if it hasn't gotten too high already.
    The second issue is that we really need reliable test results to know what is going on. Without reliable test results it is impossible to know what to do.
    The very high CC levels are suggestive of ammonia in the water. The solution is to SLAM the pool, see the directions in Pool School. Loosely speaking, a massive addition of chlorine, but not dichlor and not all at once.
    Apr 2015
    Long Valley, NJ
    7
    Thank you for the very quick reply! This is a great forum. I've read the articles on SLAMing and figured that was the right thing to do. I will stop using the Dichlor and invest in a good test kit. When I SLAM the pool should I target the FC level purely based on the CYA level? Do I need to take the amount of CC levels into account when determining how much Chlorine (bleach) to add? thanks
    35,000 gal, in-ground gunite
    Pressure DE filter
    2 HP Hayward Pump
    Solar Heating System
    Just target the correct FC level based on your CYA level.
    Apr 2015
    Long Valley, NJ
    7
    Thank you sir! I'm using the TFP CYA/FC chart, then the PoolMath tool to determine how much bleach to use. I'll let you know how it goes.
    Pressure DE filter
    2 HP Hayward Pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    Please do let us know how it goes, and if we can help.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP! Please update your signature as shown here.
    Here is some info on test kits, Test Kit Comparison
    Here is some basic water chemistry info
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Glad you are using the FC/CYA chart, what is your CYA level? Have you found PoolMath?
    Read up and ask more questions.
    Apr 2015
    Long Valley, NJ
    7
    Thanks for the help so far. I've started SLAMing today and could use some more help.
    I am using a Taylor FAS-DPD kit to test for FC and CC. Here's what I have done so far:
    Started process at noon today. Before adding bleach (8.25%) FC=0.4, CC=1.8, CYA=20, pH=7.5, TA=70. I used pool math to target a shock FC of 10. I added 5 gal of 8.25% bleach. The water was pretty clear when I started.
    1 hr later I tested and FC=3, CC=2.5. I added another 5 gal of bleach
    Tested again in 1 hr FC=6, CC=2. I added 4 more gal of bleach
    1hr later FC=4.5, CC= 4.5. I was out of bleach at that point and had some diclor on hand. Since CYA was relatively low I added 8 lbs of NaDichlor.
    2 hrs later FC=4, CC=5.5
    I bought 12 more gal of bleach, but I'm not sure where to go from here. It seems like the CC is getting worse. Should I just keep added bleach? At this rate I'll need a ton. Will the FC ever reach 12? Will the CC chlorine just keep going up? Thanks for your help.
    Pressure DE filter
    2 HP Hayward Pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Welcome to TFP!!
    Yes, just keep adding chlorine to adjust back up to shock level each time you test.
    CC may go up at first but should start coming down soon.
    Support the site
    Apr 2015
    Long Valley, NJ
    7
    Thank you!! I'll give another dose now and keep plugging along. Keep you posted.
    Pressure DE filter
    2 HP Hayward Pump
    Sep 2014
    Fort Lauderdale, FL
    146
    To give you an idea why Cc is going up...
    You have something organic in the water - algae, ammonia, whatever. When you add bleach (FC), it attacks whatever is in the water, and gets converted to CC. So, the rising CC indicates your Slam is killing off that stuff in the water - that's a good indication actually!
    CC naturally dissipates in sunlight, but not as fast as you're producing it right now. As you finish the slam, your bleach consumption and CC production will taper off, and CC will then start to decline. Just keep adding bleach and give it time...
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
    DFW, TX
    24,502
    You can speed the process along by testing and adding more bleach every couple of hours if you can.
    Casey's Avatar
    SW PA
    10,450
    You probably have ammonia in the water since you state the pool is clear.
    Keep SLAMing the daylights out of it.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    You are doing all of the right things!
    -Find TFP
    -Get test kit
    -asking questions
    -adding bleach and more bleach
    Keep it up and you will be clear forever!
    It is going to take some time to balance your pool. Well time and bleach.
    Good job!
    Kim
    Oct 2007
    Cedar Hill, TN
    252
    Quote Originally Posted by Dcommerford View Post
    Since the CYA went up with your use of diclor, your target FC needs to go up as well. Double check the chart
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    John is correct, you now have more Cya, so it will now require more FC to do the same job.
    Don't fret over the CC, part of the SLAM process is getting them down. Yes, you will get to SLAM level of FC but it takes adding more and more FC until you do, and are able to maintain that level for some period of time. You'll learn how long that time is, and be ready to dose again to keep it there and not let it fall below. You will get there.
    Essential Links:
    Apr 2015
    Long Valley, NJ
    7
    Thanks everyone. I'm making good progress. I've increased my FC shock target to 12 as the CYA is now 30. Here's an update since last time:
    I've added 4 more doses of 8.25% bleach (5 gallons each time) over the last 24hrs. The first 3 readings ~2 hours post-bleach were pretty consistent at FC=1-3, CC=1. The last reading I just did was FC=12.5 and CC=1. I have never had a FC reading over 6. Feels like I'm turning a corner!! The DE filter needed to be back-washed also. The pressure went up 10 psi after I started SLAMing. I'll check in the morning. Got plenty of bleach on hand...
    Pressure DE filter
    2 HP Hayward Pump
    Casey's Avatar
    SW PA
    10,450
    You're getting there! Keep going!
    Apr 2015
    Long Valley, NJ
    7
    Here's an update. I completed the SLAM process on 5/13 when the pool passed the overnight chlorine test. The pool is looking great and chemistry is spot on (now have a TF-100 kit). As a recap, my SLAM took 7 days and over 50 gals of bleach. Definitely got the job done and ready for summer. Thanks everyone for the advice.
    Pressure DE filter
    2 HP Hayward Pump
  20. Back To Top    #20
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Congratulations on finishing your SLAM.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
