Thread: Re-doing base on Ultra Frame 16', looking for info.
    Jul 2014
    Oakbank, Canada
    389
    I took my Ultra frame down for the winter, and am now re-doing the base. Worked fine for the last 3 years, but I decided to do the base the right way. So I removed all the sand, and once again leveled the ground, and am putting pavers under the support legs this time, along with foam sheets, and a gorilla blanket.
    What I am looking for is a measurement drawing for the paver locations. I put the top ring up, but it moves quite a bit without the liner in place so I am hoping someone has close to the exact locations for them. The last thing I want to do is have to move them after putting the frame and liner back up.
    BTW, the pavers are 2" thick, x 12" x 12", more than adequate.
    Anyone have these measurement's?
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jul 2014
    Oakbank, Canada
    389
    Re: Re-doing base on Ultra Frame 16', looking for info.
    Would someone that currently has their 16' Ultra up, be kind enough to measure from corner to corner in a few places around the top of the pool, outside edge to outside edge. That would be adequate for me to figure our from there.
    Thanks
    Jul 2014
    Oakbank, Canada
    389
    Pool measurment
    Oops..........duplicate post
    Jul 2014
    Oakbank, Canada
    389
    No need to measure anyone, my buddy came over and it was so obvious I was overthinking it. Got it all figured out.
