Thread: Wiring a new Polaris 380 booster pump motor
    My old booster pump motor on my Polaris 380 was on its way out last year. It was very loud and probably ****** off the neighbors. I disconnected it to see if I could fix the issue, but everything was so rusted, I couldn't even get the screws off of the backplate. The motor was built in 1999, so it's going on 16 years... time for a new one.
    Anyway, I confirmed that it was a 220 Volt line and the new motor comes pre-wired for 220V:
    http://www.amazon.com/Zodiac-PB4-60-.../dp/B000786GKS
    When disconnecting the old one, I had one green wire, which was screwed to terminal inside the motor (the ground), and two red wires that were connected with spade connectors to two other terminals inside the motor.
    In a 220V set up, does it matter which of the red wires goes on which terminal? I'm assuming not, since they are both red, but I want to make sure.
    Kevin
    30,000 gallon vinyl pool
    Hayward DE Filter
    Hayward Super Pump
    AO Smith 1 1/2 HP Pump (27GPM)
    Polaris 380 Pool Cleaner
    Check out the app I created to control my pool equipment from my smartphone:
    i-created-an-app-to-control-pool-equipment-with-smartphone-t61606-20.html
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Re: Wiring a new Polaris 380 booster pump motor
    You're right. It doesnt matter which wire goes on which terminal.
    The green is ground.
    Divin Dave,
    Thanks... that's what I suspected.
    Hayward DE Filter
    Hayward Super Pump
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    There should also be a bare copper bonding wire attached to the outside of the motor. Just FYI.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Quote Originally Posted by n240sxguy View Post
    Yup... got it. Thanks.
    Hayward DE Filter
    Hayward Super Pump
