Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Is this a gas line hookup for a heater?
    We bought the house and it came with a pool (which we love). In light of the mild summers we've had in Southern New Jersey, I was contemplating adding a heater. I noticed this piece of pipe coming out of the ground and I think it's a gas line, but I'm not sure. Here's some pictures:
    30,000 gallon vinyl pool
    Hayward DE Filter
    Hayward Super Pump
    AO Smith 1 1/2 HP Pump (27GPM)
    Polaris 380 Pool Cleaner
    Check out the app I created to control my pool equipment from my smartphone:
    i-created-an-app-to-control-pool-equipment-with-smartphone-t61606-20.html
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Is this a gas line hookup for a heater?
    It looks likw what would be used for gas. Do you have Nat Gas at the house? If it is you would need to compare the flow needed for you selected heater and the size pipe to make sure it would handle the flow.
    Support the site
    Yes, we have natural gas heat and hot water in the house. The gas meter is directly behind the pump/filter assembly in the picture. I'm assuming this was put in when the pool was built, so I'd have to guess the flow and pipe size would be appropriate, but I'll check it out.
    Hayward DE Filter
    Hayward Super Pump
    Feb 2014
    Upstate, NY
    390
    I'm surprised there is no shut off valve there ??? Where is the shut off valve located ??? At the meter perhaps???
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    I'm not sure if there is a separate one for this line, but there is one at the meter, which is directly behind the filter in this picture.
    Hayward DE Filter
    Hayward Super Pump
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by kodiak1120 View Post
    Yea, if the meter is directly behind the filter the shutoff could very well be there.
    Support the site
    Assuming this is a gas line, how hard would it be to hook up a heater? I would think pretty easy, since the gas line is right there. All I'd need to do is put some kind of a foundation down, hook up the gas and re-direct the plumbing.
    Quote Originally Posted by tim5055 View Post
    Although it would be kind of a pain to initially hook up the heater because I'd have to shut off the gas at the meter, which would shut off gas to the whole house.
    Hayward DE Filter
    Hayward Super Pump
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Im no heater expert at all and I dont have one. I do know however is that if you use the existing pipe, you need to size the heater properly so that you dont end up with one too big for the amount of gas that pipe is capable of supplying.
    Divin Dave,
    Feb 2014
    Upstate, NY
    390
    There really should be a shut off valve for that specific line. I actually have two (2), a ball valve at the exit point from the house and a red handle valve inches from the heater. Just an FYI.
    Once the gas is confirmed OFF, you should have no problem at all connecting the heater if you are somewhat handy. You will need electric to the heater as well.
    Jul 2007
    Suwanee, GA
    528
    Looks like a gas line to me. I would have it pressure tested before attempting to use it though.
    I had our local gas company out last week to replace our meter for a larger one and he commented that he visits a lot of houses for gas leaks and they find them in buried iron pipes for pool heaters. They unhook it, cap off the meter and go on their way. Your pipe does look galvanized (aside from the plug), so depending on the age, you may be in luck.
    As others have suggested, you'll likely have to dig up part of the pipe and check the size that is underground, they may have reduced it coming up. Depending on the length, that 3/4" may not be enough. I had to run an 1 1/4" line, and I only had 20 something feet.
    The odd route that the plumbing takes also suggests there was something there once.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Quote Originally Posted by crabboy View Post
    As does the bonding wire, which presumably once connected to something rather than being wrapped around that pipe.
    Normally don't use galvi for gas... Might want to have a plumber check it out and see what it is...
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Quote Originally Posted by stebs View Post
    Not sure where the OP is located, but here in FL, galvanized pipe is the code for gas pipe.
    kodiak1120, Since the meter is right behind your pump, the size of line that is already there is good for any size heater you decide to get. If you had a longer run, say 40+ ft, then you might need to consider the pipe size. Adding a shut off valve right by the heater is pretty easy.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Thanks for all the responses... maybe there was a heater installed at one point that was removed? The house was built in the mid-90s... I'm not sure when the pool was added, but pump for the Polaris had a manufacture date of 1999, so I suspect that may have been when the pool was installed. I bought the house in 2011, and there was no heater. It would be odd for the heater to be installed in 1999, and already taken out by 2011.
    Hayward DE Filter
    Hayward Super Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    It seems pretty clear that there was a gas heater there at some point. If the heater started leaking or failed and the previous owners didn't use the heater it makes sense to me that they would remove it and cap the gas line.
    Feb 2014
    Upstate, NY
    390
    Quote Originally Posted by pooldv View Post
    Absolutely agree. Anything could of happened between 1999 and 2011. They could of removed it just before the sale of the house as well, rather than replace and/or have the new potential owner request a new heater, assuming the heater was shot.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    I get calls all the time from folks selling their house and the heater is shot and all they want to do is have it removed so it's not included in part of the sale. So it gets removed and the line capped off. Seller now doesn't have to deal with comping the buyer for a new heater.
    Paul
    Apr 2015
    Long Island, NY
    51
    If there was a gas heater there at some point wouldn't there also be a concrete slab or some kind of pad? Maybe the previous owner had the connection installed but never had a heater put in. A good thing actually, as the cost to run a gas line can be pretty expensive if done by a licensed plumber. I just bought a house with a pool in January and have an almost identical scenario where there is a gas line next to the pool filter but no heater. There is a concrete pad, though. Actually, it's a pad made up of a group of 12" X 12" concrete pavers. I've been debating the heater question myself but may wait 'til next season. The idea of adding another $400 - $500 bucks to my monthly nut makes me shiver.
    And, BTW. Is that your pump ground wire wrapped around the neck of that gas fitting?
    In Ground 17,500 Gallon Freeform Vinyl Liner - Hayward S220T Sand Filter - Hayward Super II Pump - Kreepy Krawly Kruiser Cleaner
    If I had a dollar for every time I told my wife that there's no way we're buying a house with a pool, I'd have enough money to install the pool that came with the house we bought!
    Feb 2014
    Upstate, NY
    390
    Quote Originally Posted by Ripper70 View Post
    I'm going to guess there was def a heater there. Take a look at the pvc pipe configuration. Appears to have been cut and pieced back together.
  20. Back To Top    #20
    Jul 2014
    Peoria, IL
    389
    If the meter is right there I would not worry about that line and would size my heater to the surface area of the pool and the desired rise in temp and air temp. Running a gas line that short will not be as costly as operating a heater that has to run excessively to keep up. Just because you wanted to re-use 6' of pipe.
    And yes, it definitely needs a shut off right at the heater.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
