I have had my QC Tiger Shark since Easter 2014. My PB screwed up my coping and had to have it sand-blasted. The comp that did it said they vacuumed out all the sand - what a bunch of BS. The t-shark for the first 2 weeks would collect about 2-3 pill bottles worth of fine sand each run, plus a lot of the pebbles from the pebblesheen. Overall, it does a pretty darn good job and cleans the pool well. I run it 3-4 times per week min, and do the 4 hr run vs the default 2 hr QC time.
Mine too climbs the wall and cleans the coping, so can someone provide me w the info for the restrictor? I already have the one in that comes w the shark, but they instructions said if it climbs too much, you will need to get the additional one. this is the one I need. Also, when you added the restrictor, did it degrade the performance/power vs wout? Note, my manual was tossed-out by cleaning lady so this is why I need the restrictor info,
Finally, the 50ft cord is a memory cord, so if it get curled-up, lay it out in the straight line in the sun for a couple of days and should help...repeat as necessary. Also, the filters have 2 options for cleaning: one, let them dry in the sun, then just strum the pleats face down [plastic side up] and then tap a couple of times the plastic rim on a fence post and you'll see junk falling out...keep doing until all debris is no longer falling out..or 2, take the hose, w sprayer, hand hit the plastic side and pressure wash the filter. This should be done btw every 4-5 runs unless your filter is really dirty and will not clean-up w out water.
Thanks for the help on the restrictor, tstex
