Thread: Trying To Fix Pool Issues
    Apr 2015
    Lemoore/CA
    1
    I went into the pool store the other day because my water was a little cloudy. They tested my sample with a Taylor kit and told my that I had 0FC and that I needed to shock. My CYA at the time was 99 Which is high already and after the Shock it went up to 115. After the shock my pool is super cloudy and I cant even see my Polaris at the bottom of the deep end. What should I so?
    Tested Today
    FC-0 (after 3 bags of Leslies Power Powder)
    CH-300
    CYA-115
    Alk-140
    PH-7.5
    38,521
    Re: Trying To Fix Pool Issues
    Welcome to TFP!!!.
    1. Stop going to the pool store
    2. Order one of the Recommended Test Kits.
    3. Replace 1/3 of your water while waiting for the test kit since your CYA is not too high. You may need to replace 1/3 a few times as you do not know how high the CYA really is.
    4. Start learning about pool chemistry while waiting for the test kit:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    5. Perform a full set of test results with your new kit and post the results.
    6. Follow the ShockLevelAndMAINTAIN Process to clear up your pool and take control.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Hi, welcome to TFP!
    Please update your signature as shown here.
