Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: New pool owner
    Apr 2015
    Miami Lakes/ Florida
    17
    New pool owner
    I just bought the Taylor k2006 kit and made the following measurements:
    PH - 7.6
    TA - 80
    CH - 230
    FC - 5
    CC - .5
    CYA - 90
    I want to know if i have to make any adjustments. My previous Cya was 200, I changed 2/3 of the pool water, and brought it down to 90, pool is clear and sparkling.
    38,237
    Re: New pool owner
    Welcome to TFP!!!
    How did you get a CYA of 87ppm? The test is not that precise.
    You FC is too low for that CYA, you need to maintain a MINIMUM of 7ppm for that high CYA. See the FC/CYA Chart.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: New pool owner
    Welcome to TFP!!
    Yes, with 90 CYA (there is no 87 on the Taylor tube) your FC shlould never be below 7 and you should target at least 10 to make sure it doesn't
    I need to know a little more about your pool to assess the other numbers.
    It would help us if you would add the following information to your signature
    • The size of your pool in gallons
    • If your pool is an AG (above ground) or IG (in ground)
    • If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    • The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    • If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    • Date of pool build/install, particularly important if less then a year old.
    • What kind/model of water test kit you are using
    • Other significant accessories or options, such as a spa , SWG, or cleaner
    Support the site
    Apr 2015
    17
    Re: New pool owner
    Got 90 on the taylor k2006 and took sample to pool store they said 87
    They have some type of meter.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: New pool owner
    Hi, welcome to TFP! Time for a little Pool School. Links to some helpful articles for starting out are below.
    These articles teach basic water chemistry
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Basic Pool Care Schedule
    These articles list the recommended levels and chemicals for your pool
    Recommended Levels
    Recommended Pool Chemicals
    Use Poolmath to determine how much checmicals to add to achieve the recommended levels
    PoolMath
    Come back and ask question anytime!
    38,237
    Re: New pool owner
    Forget the pool store testing. Trust your own.
    Apr 2015
    17
    Re: New pool owner
    I am going to dump 1/3 of the water and refill from the tap to bring the CYA to at least 60, what do you think. I have to get some more reagent for the CYA testing, I used it all up. I ordered the large bottle, should be getting it in about a week.
    Sean Gosine
    10, 260 gal, Concrete, 1 HP pump, cartridge filter 100 gpm, IG pool plaster, Built 2006
    Taylor k2006 test kit
    May 2014
    Franklin, NC
    9,179
    Re: New pool owner
    Quote Originally Posted by sgosine577 View Post
    I am going to dump some water and refill from the tap to bring the CYA to at least 60, what do you think
    What are you using to chlorinate? That will determine our recommended CYA level.
    Support the site
    38,237
    Re: New pool owner
    Doing another 1/3 water replacement would make things easier. Although if you get a lot of rain, that should lower your CYA as well.
    Apr 2015
    17
    Re: New pool owner
    Are the Clorox Test Strips any good?
    Sean Gosine
    38,237
    Re: New pool owner
    No. You have a K-2006, why are you asking about test strips?
    May 2014
    Franklin, NC
    9,179
    Re: New pool owner
    No, we do not recomend test strips at all. Results are too unreliable.
    Support the site
    Apr 2015
    17
    Re: New pool owner
    Using liquid chlorine from now on, might switch to Clorox bleach, stopped using the tabs, that's what drove the CYA so high, Plus using Clorox super shock.
    I stupidly bought those strips before I bought the K2006
    Sean Gosine
    May 2014
    Franklin, NC
    9,179
    Re: New pool owner
    Stick with the K2006, the strips are not worth anything. Sorry to say, the Clorox super shock is also a bad purchase. It is also adding CYA to your pool.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    How to Chlorinate Your Pool
    Support the site
    Apr 2015
    Austin/TX
    71
    Re: New pool owner
    Tim,
    I think she said Clorox bleach. Are you saying that is a bad purchase or if she bought Clorox super shock?
    21k gallon IG free form plaster/pebble pool, pentair FNS Plus DE filter, pentair sta-rite 2hp pump, pentair booster pump, pentair rainbow 320 IC and paramount ultraUV, Pool Build - 2015
    May 2014
    Franklin, NC
    9,179
    Re: New pool owner
    Switching to Clorox bleach but also "using Clorox super shock." which if I am correct is dichlor, which has more CYA than the tabs
    Support the site
    38,237
    Re: New pool owner
    Tim said the Clorox Super Shock is a bad idea. It is rather annoying now that Clorox has put its name on everything.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: New pool owner
    Quote Originally Posted by rgswff View Post
    Tim,
    She said "plus using Clorox super shock." Plain Clorox bleach is fine.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Apr 2015
    Austin/TX
    71
    Re: New pool owner
    Quote Originally Posted by n240sxguy View Post
    I missed that so thanks for pointing it out. Didnt mean to confuse the issue.
  20. Back To Top    #20
    Apr 2015
    17
    New Test Results after heavy rain.
    I added 2 gallons of 6% bleach
    FC 16
    CC .5
    PH 8
    TA 100
    CH 190
    CYA 80
    It is still raining so i will wait to retest before doing adjustment
    Sean Gosine
